The Ape Man
07-21-05, 02:39 AM
Not mine. It didn't sell with a starting bid of $29.99 last time so the guy re-listed it.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=7987922823
question. since its a 76 intake, would it be smaller in flow due to emissions?
The Ape Man
07-22-05, 10:58 PM
Nah. An added emissions plus would be the EGR valve. Does nothing at full throttle but with proper tuning actually helps fuel economy.
huh, so emissions are mostly in the heads and cam? nothing to the intake or the carb?
The Ape Man
07-23-05, 01:07 AM
"Emissions" is a buzz word used to sell "high performance" parts. It gives license to remove all kinds of engine items and buy whiz bang pieces.
really? not trying to be a smartass or anything, but is that fact or opinion? cuz the 500 dropped 210 hp between 70 and 76, and im curious as to what made it drop. i always assumed the cam played a big role in it.
The Ape Man
07-23-05, 07:44 AM
You are not being a smartass. You are simply asking questions. That sure beats wasting time and money on your project.
Remember when reading anything about "high performance" to take information with a grain of salt when it comes from someone trying to sell you something. That is not to say that there aren't any good speed parts for Cadillac engines. It's only a comment on the sales technique.
Pay close attention to people who actually turn wrenches for advice. There are small armies of those who read articles and drool over this or that. That's fine but any information you get from these people is in fact at least second hand. If you hear that Joe Blow says to use a square muffler bearing to make your Cadillac fly then go ask old Joe himself. Then find out who else bought a square muffler bearing set from Joe's Performance and find out if it lived up to expectations.
I've have seen some pretty good articles on Cadillac engine build-ups. They don't look like an infomercial either. You can take out a balance sheet like an accountant and see what you get for your money the way these are written. They didn't simply say to throw out this part or that because they were "emissions" parts.
The 500 only lost several percent in power from '70 verses '76. The difference was mainly a reduction in compression. Auto manufacturers knew that lead was no longer going to be used to increase octane so they reduced compression. EGR was introduced to reduce oxides of nitrogen. Guess what. EGR means little or nothing nothing at full throttle on these engines. The later engines had H.E.I. and the curves were optimized for fuel economy. The reason that you see a reduction of 210 horses is due mainly to the change from gross to net horsepower rating in 1972. If you actually pull up every part number for both engines and compare it can be seen that not a heck of a lot was changed. The part numbers are available in some of the older Motors Parts and Labor Time Guides. As an example, look at a '71 472 verses a '72 472. You see the reduced power rating but just about no difference in what is under the hood.
Good luck with your project. You picked a great brand to start with.
yeah, thanks, that does make sense. how much hp do you think got put out to the wheels in 68-71 before they did the bhp? around 290- 300 maybe? i guess loss of compression would decrease power pretty good, thanks for the help
The Ape Man
07-24-05, 11:44 AM
I really don't know how what the numbers would add up to. Only time I've ever used a dyno would be for state inspection. You become a dinosaur very quickly in the auto business. That's me. Last time I went to Englishtown (1986) with my Cadillac, the 1/4 mile time, weight and speed were plugged into one of those old Peretson Publishing slide rules. Those spit out horsepower numbers based on what you put into them. It came up with a number like 235 or something close to that for my horsepower. I looked up the net horsepower rating for my engine and it was 230! Maybe just dumb luck. I said to myself, "self, this slide rule is works pretty good". Next step was to plug that same horsepower figure into a car with 1000LBs less weight. The quater mile times sure looked good.
Maybe someone knows where a similar calculator is online.
yeah, that does sound kinda cool, ill try looking a bit for one of those calcs.
