: taillights not working and fuse keeps popping...
jaynjessie
07-20-05, 01:33 PM
Hi I have a 2000 Escalade and recently the taillights quit working. The fuse is blown and everytime we insert a new one and turn the ignition or manually turn on headlights....it POPS!!!!:hmm:
PLEASE HELP!!!!!:bonkers:
Thank you,
Jessie
99escalademan
07-20-05, 03:22 PM
I have a 99 and my right tailight is out.. I cant figure it out either, i have checked all the fuses and tried new bulbs.
nickc280
07-20-05, 03:37 PM
that sucks you have a short somewhere, did it just start happening?? did you do anything different??
jaynjessie
07-20-05, 03:52 PM
No haven't done anything different...just happened out of no where!!! Took it to a friends shop and they wanted $500 (not including labor) :rant2:.....so wanted to see if any of you fine people have had any similar problems and how you went about fixing it...
jaynjessie
07-20-05, 04:01 PM
I've been trying to search for common problems...like maybe there is an electrical problem with these years...but was unable to find anything!!!! Sorry!!! But if I find anything that may help you......I'll let you know for sure!!!
99escalademan
07-20-05, 10:19 PM
Talked to the caddy dealer today. There was a similiar problem with trailblazers from 00, there was an upgrade pice from them.
I needed a new chip plate, where you plug all the bulbs in. There was alot of corrosion which made the short. Check your bulbs and see if they have a burnt appearnce on the back. Replacing all bulbs should work. If not the new part is 80$, but worth it since a ticket would be over 100$.
slimm44
07-21-05, 12:10 AM
i needed a new taillight circuit board too for my 99 because of excess corrosion. i got one off ebay for like $25. not genuine GM, but it worked just as well.
dnyce617
07-21-05, 09:42 AM
I had the same thing on my 2000. The dealer replaced the circuit board under warranty at the time (2002.)
