View Full Version : 24 Psi
GAGS-V
07-20-05, 01:18 AM
Anybody else have this problem? I fill my tires to 30 psi cold and things are fine for a short while. After a short time goes by I have one tire that drops to 24 psi. it does not go any lower than that. I then fill it up again and go thru the same thing all over. 24 psi is it's magic number but it's driving me crazy.:confused:
ctsvett
07-20-05, 02:05 AM
a few tsbs exist on this:
http://www.cadillacfaq.com/faq/answers/tsb
Could be:
-Make sure the TPS nuts are torqued properly
-TSB on alloy wheels leaking (use different sealant)
-Small puncture (not likely)
-Are you checking the pressure cold?
Some ideas....
Reed
NIK
07-20-05, 08:37 AM
I had the same problem with my right front tire - torqued the TPS nut a little tighter and, viola! No more problem.
SBONES
07-20-05, 09:04 AM
that happened to me. try tighting up the nut at the valve stem. that fixed mine. it was leaking...
GAGS-V
07-20-05, 11:11 PM
thanks guys, I will give it a try...
