: 2004 DHS - CMP location ?
GM_Ridin'
02-18-14, 02:29 PM
I'm actually in the middle of replacing my sensor so i removed the surge tank but I don't see the cam sensor. I have a '04 dhs so did they place those sensors somewhere different?
Submariner409
02-18-14, 04:14 PM
Your CMP is in the front (passenger end) of the right (rear) cylinder head, in line with the exhaust cam sprocket. Below and behind the P/S pump.
Your question does not belong in Tech Tips. Moved to Engines, Northstar thread "2004 DHS CMP location ?". Please read the Tech Tips forum description.
GM_Ridin'
02-18-14, 07:45 PM
Ok thank you. I actually googled my issue and that thread came up. I actually don't think I'm going to need the cam sensor I got a code for the crank sensor a and b (P0335 and po385) so I returned the cam sensor and bought those crank sensors.
Ranger
02-18-14, 08:31 PM
CKP sensor failure is MUCH more common than CMP sensor failure.
GM_Ridin'
02-19-14, 12:51 AM
Yeah that's what I thought. My code didn't pop up anything for the cmp just both the ckp.
