delzy
07-15-05, 02:19 AM
Perhaps you saw my earlier post regarding wild idle on my 95 sls: http://www.cadillacforums.com/forums/showthread.php?t=45720
Well, I've replaced a knock sensor and the ISC motor and the symptoms are still the same.
So I read out PD01 (Throttle Position - Degrees) and it is jumping all over between 12 and 25 sometimes jumping to 45 or 55. I go out and pull the connector from the sensor and no change (it still keeps jumping around just the same).
I measure the dc voltage at PCM terminal 1B15 (throttle position sensor input) at the PCM and it is going from .2 to 1.8 vdc through the range of accelerator pedal position. The voltage corresponds with the pedal, but the pd01 reading just keeps jumping around randomly as before. I also checked the voltage at pcm 2c1 (sensor return) and it was rock solid at .2 volts through all accelerator pedal range.
I'm also getting a P026 (shorted throttle position switch), but I'm sure that's because the PCM is calculating my throttle position around 30 degrees when my foot's off the pedal.
I'm still fighting the P132 (knock sensor problem). It's input votage is supposed to be between .3 and 4.2 vdc, but it is riding up around 8 volts. I've traced that circuit, and I'm pretty sure its intact.
These problems happened at the same time. I'm $167 into parts replacement and dreading buying a new PCM if that's not the problem. Do you think the PCM should be next? I've given it bbob's rap test and no change. Will I have to get the PCM programmed by a pro or will it just work when I plug it in?
Thanks in advance. I really need the help!
