View Full Version : Reverse problem
FLsilverV
07-15-05, 01:06 AM
Anyone else having the problem its happening to me more and more often i go to put the V in reverse and it wont go into gear sometimes?:banghead:
heavymetals
07-15-05, 01:48 AM
A lot of the time.
I just put it in another gear then put it in reverse.
OuTLAw
07-15-05, 02:21 AM
Happens quite a bit to me too.
GAGS-V
07-15-05, 02:29 AM
Same here. I put it into reverse when I park if I need to back out of the spot I am in. Keep an eye out and see if it gets worse...
1gCtsV05
07-15-05, 08:27 AM
as stated it is a problem... with most manuals actually... usually you roll alill to move gears... but you fan pop it into any gear (i usually use 5th / 6th) and go right into R.. no biggie!
Mowgli
07-15-05, 09:06 AM
The T56 (tranny is used in quite a few cars GMs and Fords) is notorious for this. My last car had a T56 in it too and it did the same thing. Its not the shifter's fault or your car. The price for strength? eh.
sti convert
07-15-05, 12:08 PM
I just put in first, run er up to 6K, hit the line lock, dump the clutch, warm up the tires...and then try reverse again. Works every time.
