delzy
07-12-05, 07:56 PM
Hello and thanks in advance for any help. I have a '95 SLS with about 75k miles on it. It has been an excellent car since we got it 5k miles ago. I apologize for the long post to follow, but hopefully, you will be able to help if given enough detail.
I was on my way out of town for a second 2500 mile road trip and about 3 miles from home, the car just died. It wouldn't hold idle but would run if I feathered about half throttle. I slammed it in gear and limped back home. While driving home, it got stuck in 1st gear for a bit and then revved up to about 3000 at a stop light while I had it in neutral. We got back home and parked the caddy and loaded up my E-350 work van for the trip. That was a week and a half ago.
Yesterday, I pulled the codes. They were all history, none current:
P021 Shorted Throttle Position sensor
P022 Open Throttle Position Sensor
P026 Shorted Throttle Position Switch Circuit
P032 Open MAP sensor
P057 Shorted Transaxle Temperature Sensor
P062 Cruise Control Vacuum Solenoid
P070 Intermittent TP Sensor
P091 Transaxle Range Switch Prob (Cruise)
P094 Transaxle Shift 'A' solenoid Problem
P095 Engine Stall Detected
P132 Knock Sensor Circuitry Failure
I believe these all happened on that one short drive.
When I turned on the key (but not the engine), the ISC starts clicking for about 10 seconds. when I shut off the key, it clicks again for about 15 seconds steady. I have adjusted the ISC and cleaned the throttle body when we first got the car.
So I start the car to see if its all just history, but no such luck. The cars idle is about 2000 rpm. I pull the copdes and all are the same except P132 (knock sensor circuitry failure) is current. I pull out my trusty FSM and start to diagnose the P132 according to the trouble tree:
Backprobing PCM pin 1A13 gives about 8 volts for a couple seconds then drops down to an acceptable 0.48 VDC. So I start the car and the voltage rides between 8.5 and 10 volts. I shut down the engine, pull connector 1 and turn the ignition back on - 0VDC. Pull the connector and find about 3 ohms resistance on the circuit from terminal 1A13 to the terminal on the knock sensor connector. I check CKT 496 for shorts to any other pins on connector 1 and find none.
I picked up an aftermarket knock sensor from my local NAPA warehouse for $40 and get it installed. I had to go through the passenger front wheel well. A nice tool would have been a 7/8" stubby open end, but of course I had to use a mini vice grip on the threads as I don't have any stubby wrenches. I cleared the codes, pulled the battery terminal for a minute or so and started up the car with the greatest of expectations.
Same symptoms - fast idle, stall, unstable engine RPM. Still seeing about 9VDC on terminal 1A13 while the engine is running. Here are the new codes (history unless noted):
P015 Open Engine Coolant Temp Sensor
P026 - Current while running
P032
P061 Cruise Control Vent Solenoid Problem
P062
P070
P071 Intermittent MAP sensor
P073 Intermittent Engine Coolant Sensor
P095
P132 - Current while running
I052
I also pulled PD40 - knock retard angle (.7-1.6) and PD41 - Knock events (0).
At this point, I'm thinking the PCM needs replacement. I'd rather not spend the $250 to learn the problem is in the harness or something stupid like that. How likely is it that a new PCM would be damaged if there is an existing problem in the harness or a component. Is there a good place to order the PCM to save a little jack?
Also, will I need to get the car professionally serviced if I replace the PCM? How much should that cost if so?
Maybe I'm in over my head here, but I'd really like to get this car fixed as cheaply as possible. It has been a great car, but I'm really not looking forward to my wife's "I TOLD YOU SO's!!" - She wanted a Toyota!!
Please help. Speculation is welcome, but I'm really looking for someone who knows what I should do next.
P032
P062
P070
P095
I052
