wpgresh
07-11-05, 03:50 PM
Check engine came on... cc display showed code 25. Also, bottom door courtesy lights will not come on and under dash courtesy lights com on when I press the brake pedal. Need help. Thanks, ... wpgresh@atlanticbb.net
| View Full Version : Code 25 on 81Cadillac Seville 8-6-4 V-8 wpgresh 07-11-05, 03:50 PM Check engine came on... cc display showed code 25. Also, bottom door courtesy lights will not come on and under dash courtesy lights com on when I press the brake pedal. Need help. Thanks, ... wpgresh@atlanticbb.net kc81cadman 07-21-05, 03:32 PM Codes, no clue (not enough experience yet). Electrical is something you really have to trace out from the light back. Having a schematic helps alot. KC. | |
