View Full Version : Stock Airbox Observations
ace996
07-10-05, 04:53 PM
I finally pulled the stock airbox to see what was going on....its ugly. That is one tortured path through which our air needs to travel. Here's what I did...
1. Pulled the box out
2. Cut the rubber inverted-nose snorkel out...I used mini zip ties placed behind the backing washers to stop any rattle, as they were loose.
3. Cut the end of the rubber snorkel and fastened it(the flare, not the nose...I threw that out) to the end of the "dual" pinch-tube intake..looks kinda stock now, still.
4. Put it all back together
Now it appears that there is a straighter shot of air to the box, and it may have added a little more "ram" to the system.
I plan on using some flex tubing to route a real intake pickup from the driver-side of the grill. Summit has some nice pieces that may work well. Once I can get air to the airbox location, I probably have to go LPE intake...and StealthV's intake tube.
I don't think anything has changed, ie. more power or sound, it was just a fun exercise in the garage...and I hate leaving sound-suppression devices on my intakes.
Ve good,
ace996
monster500s
11-04-14, 05:56 PM
Can post a pic of ur mod
joshuajohn1981
11-05-14, 12:07 AM
You might have just gotten the record for pulling up an old thread. Haha.
monster500s
11-07-14, 03:48 PM
lol just got an 05 cts v 6 speed just trying to some cheap mods to start with
rand49er
11-09-14, 01:54 PM
Get a CAGS eliminator and a shifter first, then check back in here.
Make sure you bring some credit cards. :D
jeph054
02-18-15, 10:00 AM
Is the CAGS Eliminator the same for all the GM 6 speeds? GTO Corvette GXP CTSV Etc?
rand49er
02-18-15, 01:58 PM
Is the CAGS Eliminator the same for all the GM 6 speeds? GTO Corvette GXP CTSV Etc?Don't know the answer, but if you do a tune, the tuner can turn it off in the PCM.
Becker
02-22-15, 04:59 PM
No it is not the same CAGS connector.. do some research on CAGS resistor bypass that is how I did it.. also if you ever were going to get it tuned just do it with that..
CAGS is annoying but not the worst thing
