: LS6 Engine Parts (out of 04 CTS-V)
Midamracer2
02-03-14, 01:25 PM
Stock LS6 engine components pulled off my 04 CTS-V.
$450- 243 casting Cylinder Heads- completely untouched, perfect bare model to be worked on. Off an LS6 engine so it has the good sodium filled valves. Must upgrade the stock valve springs if your planning on running a high lift cam.
$350- LS6 intake- Has 24lb injectors and fuel rail that come installed on it. Completely untouched as well. Flows great. If put on LS1 its worth 20HP.
$100- Stock LS6 Camshaft- 204/218 .551 .547 117 LSA. Great cam for a blown engine very little boost leakage. (Comes with Lifters and Push Rods)
Also have:
-LS6 Oil Pump (no issues whatsoever, 50lbs at idle)
-Timing Chain
-LS6 Intake Valley Cover
-Corvette C5 Fuel Rail Covers (never installed, does have small hole in one by the C)
- 04-07 CTS-V Strut Bar (with LS6 Emblem)
- Flywheel and clutch assembley off 04 CTS-V
Make offers on these smaller items.
Kevin- kevingentile979@gmail.com
Strike_Zero
02-09-14, 01:15 PM
Email and PM sent.
Thx,
-=PJ
