View Full Version : '99 trunk door wont open
07-03-05, 01:36 PM
i need to change the brake light bulb and the rear trunk door wont open, is there anyway to manually open it, i can take the cover off the inside part.
09-22-05, 10:47 PM
I have the same problem, let me know if you find out something.
09-22-05, 11:14 PM
if you can spray some wd-40 on it (with the little straw if you have it). when i first got my lade, it stuck really bad and i had to press the key fob button 3-4 times before i could actually open it. sprayed it thoroughly with wd-40 and it worked great.
