View Full Version : ABS/Traction lights on
06-28-05, 01:10 PM
I started my car today and the ABS and traction control lights came on. I got 3 codes, 121, 131, 135 FL, FR, RR wheel speed sensors are malfunctioning, what the hell??? All at once?
I am also getting code 02's #111 and 126, says Air mix motor circuit(Circuit Shorted) then 126 is Serial Date Communication (Circuit shorted to B+, shorted to Ground, crcuit open.)
Perhapes code 111 can explain why the air is so smelly behind vehicles, supposedly with the fan on high air should recirculate, with the fan on low air comes in from outside the car.
06-28-05, 06:12 PM
Strange, I started up the car and the ABS/Traction control lights went off. Then something strange happened, the LCD display for the speedometer went haywire, it lit up all the digits on there in a DIM backlight.
like on an alarm clock, you have 0, when the power goes out and returns it goes to 8, basically all the digits light up, thats what the speedo and everything else on there was doing. Spooky.
