odysseus
06-28-05, 12:23 PM
So I saw these on EBay (V disks and calipers) and it got me to thinking again, after close observation. The CTS rear caliper (I assume it's the rear) looks to be exactly like the front, with the exception of about 1" shorter mounting ears. With the CTS and CTS-V knuckle being identical, the V calipers should bolt right on the CTS knuckles.
Of course putting V calipers on the knuckle with stock CTS disks would result in the caliper being about 1" further out (14" rotor has 7" radius, and our 11.9" rotors have ~6" radius) . . . you see where I'm going? If one bolted the rear V caliper on the front CTS knuckle the radius should be about right for our stock rotor. I don't know about rotor/caliper offset and width, though. Now we need a guinea pig who has access to a V rear caliper (there is no PN in the Parts list for the rears), to do a test fit. How cool would it be to have slotted stock rotors with V calipers on the front, with 5 lug wheels?!?!
I know there will be naysayers, but I refuse to discount it until someone actually tries to bolt one on and verify it. The fronts only run about $100 at GMPD, so I assume the rears are similar in price (if we can get a PN). All of this is null and void if it's the front caliper with the shorter ears, and putting the rear on the front results in 1" further OUT.
It would also be cool (and very informative) if HaveBlue would test fit the V front and rears to his new 14" Baer rotors.
