BeelzeBob
06-27-05, 01:19 PM
I posted this in the "Lounge" section but it is easily overlooked there and is certainly important for anyone with a Cadillac that tows trailers....with the Cadillac or any other type of vehicle. If you have a trailer be sure and read this....
I was servicing my snowmobile trailer for next season and uncovered a problem that could be present on most any trailer out there that uses the torsion bar style axle and/or an axle with the EZ Lube style of bearings...i.e...those that have a zerk in the end of the spindle that allows the grease to be forced to the rear bearing. Those axles have a dust cap on the hub with a little rubber grommet sealing the center of the cap that can be removed to see the zerk underneath.
Those style of axles do not use a cotter key to retain the axle nut. They have a tang washer that locks the axle nut from the ID of the nut. The spindle has a flat machined in it that the D shaped hole in the tang washer engages so that it cannot turn. The tang washer has a tang bent off the flat on the ID that forms the "D" that lies inside the nut and engages the castling on the nut from the ID.
Like most people with these style of hubs (that never need disassembling and repacking) I simply pump fresh grease thru the hubs once per year and feel the hub for smoothness and tightness. Imagine my surprise when I finished up and gave the right side tire one last spin (in reverse) when it wobbled and fell off.!!! A moment ago it felt perfectly fine when the tire was off and I spun the hub and felt the bearings.
Upon dissassembly I discovered that the tang on the tang washer had fatigued and broken off and the only thing keeping the axle nut on was the fact that the normal rotation of the wheel was in the "tight" direction.
Imagine my further surprise when I pulled the left hub apart and discovered that the tang washer was broken on that side too!!! Fortunately it had jammed in the threads when it broke off and kept the nut from turning.
Bottom line is that if you have a trailer with the EZ Lube hubs do NOT take for granted that the axle nut retainer is OK. Pop the dust cap off, remove the axle nut, replace the tang washer and reassemble. The only way to tell the condition of the tang washer is to remove it and it is just as easy to replace at that point.
Like many problems like this I am probably not the only/first one to experience this. The axle supplier has changed the axle nut retainer to a totally different design. The latest and greatest is a lock that encapsulates the axle nut AFTER it has been installed and adjusted. The retainer snaps over the nut and engages the flat on the spindle to retain the nut by holding the OD of the nut. You can retrofit your axle nut to this style retainer if you buy the new retainer and a new nut and thicker D shaped thrust washer.
CHECK YOURS TODAY. I was pretty lucky to catch this in the warm garage instead of on I75 in a blizzard after the tire and wheel and hub dissappeared into a snowbank in a ravine....LOL.
