View Full Version : Northstar engine numbers
ianr57
11-04-03, 12:30 PM
Can anyone tell me how to identify the year and version of a used Northstar engine from the number stamped on the casing tag: 6TU299231 ?
Katshot
11-04-03, 12:58 PM
That is the VIN Derivative plate and it decodes as follows:
6=Cadillac
T=1996
U=Hamtramck Plant
299231=production sequence number
bobitchin
02-21-07, 02:25 PM
Hi,
I have a '99 STS and I was told it had an engine from a newer Cadillac installed. How can I tell what year and model the engine came from? The number on the tag at the rear of the engine has the following: 619MLNHOWC2.... then to the right a 9ML, then at the bottom 24209619.
Thanks
codewize
02-21-07, 02:38 PM
Katshot; you should know that if you give a man a fish you feed him for the day, if you teach him to fish you feed him for life.
6=Cadillac
T=1996
U=Hamtramck Plant
97DevilleConcours
11-22-12, 09:51 PM
Is this plate visible by just sticking a flashlight under the car?
Submariner409
11-23-12, 09:18 AM
It's not a "plate' - it's a machined pad on the right side of the engine bloc, toward the front. The VIN derivative is either stamped or etched into the pad.
You really need the car up on a lift ............
