View Full Version : power loss problems cant burnout anymore.........
ocjmakaveli
06-25-05, 03:20 AM
can low trans oil level affect performance?
how about diff. oil levels?
I haven't been able to burnout my wheels anymore the engine feels the same but somehow the power isnt being transmitted as efficiently as it was before I might do a tranny swap soon if this keeps up..........
any input is appreciated
davesdeville
06-25-05, 05:31 AM
Low tranny fluid can cause it to "slip" more than it should. Diff. oil isn't used in a hydrolic system, it's mostly there for cooling and lubrication so I wouldn't blame that immediately. I would however fix either problem immediately.
BluEyes
06-26-05, 01:39 AM
remember to check the tranny fluid with the engine warm, and running (10-15 minutes of driving at least) and the tranny in park.
Also, be sure you get Dexron-Mercon trans fluid if it needs any, that's GM's formula.
ocjmakaveli
06-26-05, 10:23 PM
I feel like its slipping more in 1st gear than it used too.
N0DIH
06-27-05, 01:18 AM
Can't do a burn out?! That is serious loss of power on an LT1 car!!!
Any noise from trans? My THM375 (not B) plugged the filter and groaned, and lost pressure fast. I got it hope did a trans filter and it was as good as new.
ocjmakaveli
06-27-05, 03:05 PM
no well the other thing is that its hard to do burnouts with my pirelli tires because they grip so well........
if i put the stock michelins i can still burnout fine.......
the thing is a couple months ago i could burnout a little with my pirelli tires but not anymore.......
before with my stock michelins my tires felt like I was always driving on ice because any little pedal force would make my tires squeel
N0DIH
06-27-05, 03:10 PM
Check plugs, see how they are reading. See if they are getting black or white. If they are white (bone white), lean, if they are black dry/sooty, fuel, if they are black oily, oil.
Make sure plugs/wires/Optispark are ok. Coolant temp ok?
Any issues when cold vs warm?
ocjmakaveli
06-28-05, 10:26 PM
no its the same regardless of temp
I just feel as if the tranny doesnt engage as it used too
N0DIH
06-28-05, 10:36 PM
Is trans filter getting plugged up?
Can't hurt to change it and the fluid. Look for debris in the pan, take any larger chunks to a trans shop that you and the Cadillac dealer trusts.
