View Full Version : Swap Time!
old school
11-03-03, 07:16 PM
OK, I've been bitten by the big cube bug. I have a 64 Pontiac LeMans Convt that needs a heart transplant real bad.
The car has a 214 ci "engine" and a close ratio Muncie 4-speed. This should be the same swap as a Chevelle or any other mid 60's mid-size. I have a sbc sitting in the garage, but I really don't want to put it in. I've been burned on the Pontiac sites because I'm not putting a Pontiac engine in a Pontiac car.
Frankly I'm not concerned with the "rules". This car is for fun not for winning a concourse event. Rat Fink sticker on the glove box and a fake bullet hole in one of the dents. Rules are for the other guy.
Which gets me back to the question.
I want to keep the 4-speed. Does anyone know what it would take to mate a 500ci to a Muncie. Automatic is not an option.
This car is being built as if it was an old street fighter. You know, sitting a little high, dual exhaust through glasspacks, 4-speed, 4-barrel, dog dish hubcaps on steel wheels, you get the picture,...old school. I'm not going to be racing it so I won't need the heavy duty parts or performance packages. Bone stock would be alright.
I've been to several sites with no luck. I find it hard to believe that this hasn't been done before.
Any help would be appreciated. Thanks.
Jim
lux hauler
11-03-03, 08:24 PM
Here (http://mywebpages.comcast.net/caddycarlo/caddycarlo.html) is a site for you to look at.
There's some info there somewhere about mating a Big Cadillac to a manual tranny.
old school
11-04-03, 09:20 AM
Ouch!, I was really hoping I could do this without too much machining!
Jim
lux hauler
11-04-03, 06:50 PM
Jim
Actually, according to that site, machining is not necessary. Just drill the center of the crank and install the bushing.
You'll need a bellhousing and flywheel that'll work with the Caddy too. The flywheel should be a bolt on. I'm not sure about the bell though.
old school
11-05-03, 05:28 PM
OK, say I get brave and take a hand drill to my crank....
What flywheel is a bolt on. A big block GM? or an aftermarket? I have found a site that sells an adapter for the bell so I don't think that would be a problem.
As for motor mounts, are there any bolt-ins, or adapters that you may be aware of? Would it be similar to the mounts on your truck?
Jim
lux hauler
11-05-03, 06:40 PM
Maximum Torque Specialties (http://www.500cid.com/mts/index.htm) (MTS) has the flywheel that you need. I believe the tooth count for the Caddy is unique therefore other flywheels won't work.
MTS also has different motor mount set-ups....I'm not sure which one you would need though.
