View Full Version : Installing avec-n2 pioneer deck what colour is the Vehicle speed sensor?
Sta11ion
06-23-05, 01:04 PM
Installing avec-n2 pioneer deck what colour is the Vehicle speed sensor? Does anybody know the colour behind the cluster, I was looking at a old thread but someone took out the colour. Thanks By the way 02 ext
onefat99
06-24-05, 01:19 PM
For the avic-n1 or avic-n2 you don't need it. The avic refreshes its location quite a bit of times per second. In the past when I have installed these in I rarely hook that wire up and haven't had any issues.
Sta11ion
06-24-05, 05:39 PM
I wanted to add the speed sensor because I wanted to see the speed and vss for the vehicle does anyone know?
Sta11ion
06-29-05, 03:25 PM
Its the green with white strip
vietfob714
06-30-05, 01:18 AM
where is the wire located?
Sta11ion
06-30-05, 12:11 PM
In the back of the cluster
flyingdutchman
06-30-05, 01:59 PM
Cluster connector A4
flyingdutchman
06-30-05, 02:00 PM
Stock radio connector E2
Hotrodfmhell
01-31-06, 08:15 PM
Another question about this, where is the reverse light wire so you can tap in for the back up camera single input?
Thanks-
senility
02-01-06, 07:11 PM
Thanks-
I tapped into the trailer backup wire in the fuse panel under the hood.
Dan <><
Hotrodfmhell
02-04-06, 02:57 AM
Thanks I'll give that a try-
fast66
02-04-06, 03:21 AM
Dan <><
Thanks, just bought the avic n2, will see if it works.
senility
02-04-06, 11:42 AM
Hey HotRod and Fast,
In your owners manual you can find the fuse that the trailer backup light uses. It's on the left midway from the top, when facing the fuse panel at the left fender. I think it's a 10 amp fuse. Pop up the fuse panel, put the vehicle in reverse and start probing with a test light. If you can't find it, let me know and I will look at mine and post the wire color.
Dan <><
Hotrodfmhell
02-04-06, 03:00 PM
Seems like there should be something in the gauge cluster. It would make it closer to the radio. I guess going though the fire wall is not a big deal, but don't want the wire to show.
