streetwise
06-22-05, 03:33 PM
i am installing a navigation unit on my 03 ext and i need to wire it into the odometer i believe it said. does anyone know which wire it is behind the cluster or do i need to splice into the wire in the engine compartment? any help is greatly appreciated.
rokum99
06-22-05, 08:26 PM
I believe you are talking about the VSS ( Variable Speed Sensor ) wire. You should not have to do the splicing, you should already have the feature. The unit, I assume is a Touch Screen. It will be all Plug N Play.
If you did not purchase a "Virgin" unit then all you should have to do is have the Dealer reprogram with your VIN Number. Hope this helps.
