: Changed fuel pump for 20 bucsk........(and some diy grease monkeying)
rs408
01-11-14, 10:03 PM
1997 EL DORARDO, ETC
Helped my buddy change out his fuel pump with this aftermarket kit www.ebay.com/itm/120962298066?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649 (http://www.ebay.com/itm/120962298066?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649) {089 E3265 FUEL PUMP GMC S15 Jimmy 19 92 93 94 95 } ........really just read some rare posts on the subject and went at it..........it its do able......but recommend extra hand..........strictly weekend amateur mechanix advise.......
TANK REMOVAL
1. Back car onto ramps ( or put on jack stands). Tank is below rear seat of car more or less....brakes/ blocks...
2. Disconnect battery
3. Remove fuel.....( We just had 4 gallons or so.........don't do it with a full tank unless you have large containers for storage.
4. Disconnect electrical harness on back of fuel tank. Disconnect hose by fuel filter.......press white plastic tabs and pull out....(this would be 3rd hose on Fuel Pump. Disconnect 1st and 2nd lines from fuel pump.....this can also be done once tank is lowered.......these also have plastic tabs.
5. Disconnect 2 fuel filling Rubber tubing from tank......screwdriver.
5. Remove screws that hold heat shield above muffler line 8mm (right side of car).........otherwise you can't reach the front right strap screw.........
7. Remove front strap screws, and rear strap screws.........total 4 screws 1/2 inch. Remove straps
8 Use jack to lower tank.
9 Lower tank.........disconnect line 1 and 2 if not done so already....
PUMP REMOVAL/ EXCHANGE PUMP WITH OLD HOUSING REUSED.
1. Use 2 hammers to knock out holding ring.
2. Carefully remove fuel pump.
3. Disconnect wire harnesses
4. Press tabs and remove pump unit.......
5. Install new pump into old housing.....(you may need to cut rubber house to same height as old pump)
Note: One of my wires. from 4 wire harness from the old pump was fried, so we jimmed one wire through the hole in the harness...
6. Solder, and electric tape new wires.......
7. Close up Fuel Pump unit.
8. Install back into tank..........
REINSTALL TANK.....
1. Get that right side, by the firewall, up first, use and jack and a friend.
2. Connect all hoses.
3. Connect electrical harness.
4. Connect straps.
5. Connect firewall
6. Refill fuel tank.
7. Start her up, your done!
...........will post a few pics.....but didn't take many.......
176042
176050
176058
Line #1
176066
pull out red and grey tabs to release harness
176074
ready to reinstall into tank....
.......notice the electrical tape and the red wire we jimmied in....
176114
176162
