Mutlu
06-20-05, 01:36 PM
I received a Mallett shortshifter for my bday and just received my UUC, which I had bought last week.
Which one should I have installed?
| View Full Version : Mallett or UUC.... Mutlu 06-20-05, 01:36 PM I received a Mallett shortshifter for my bday and just received my UUC, which I had bought last week. Which one should I have installed? 1gCtsV05 06-20-05, 01:43 PM i love my uuc shifter... do they look the same? compare the bushing... both stainless steel or just the uuc? go stainless if not.... Mutlu 06-20-05, 01:45 PM The Mallett one does not look stainless...so you say UUC then? The Mallett one is shorter in length though. trekster 06-20-05, 01:57 PM Uuc lasstss 06-20-05, 02:21 PM If you want a noisy handle use the Malett. If you want no noise, use the UUC. Also the malett isnt a short shifter, its a short handle! :eek: wildwhl 06-20-05, 02:25 PM I have the Mallett shifter...and I modified it. If you have the UUC - then go with the UUC. It is the better of the two, IMHO. StealthV 06-20-05, 02:27 PM Love my UUC, Lasstss bushings and Wienk foam mod - GM needs to copy this setup vertabim for future production runs. No noise, crisp snick, snick shifts. lasstss 06-20-05, 02:44 PM Love my UUC, Lasstss bushings and Wienk foam mod - GM needs to copy this setup vertabim for future production runs. No noise, crisp snick, snick shifts. Thread jack... Rick, you have the stuff to reprogram the PCM? I should be ready in a few weeks. Im not going to mess with that.. Some things certain people shouldnt fool with!:D wildwhl 06-20-05, 02:46 PM Heck, does Rick reprogram PCM's! Check my sig! StealthV 06-20-05, 04:38 PM Thread jack... Rick, you have the stuff to reprogram the PCM? My V didn't gain 60 rwhp on its own. :lildevil: lasstss 06-20-05, 05:01 PM My V didn't gain 60 rwhp on its own. :lildevil: Ok, where did they stuff the PCM? I havent looked for it and I know its in the manuals. (easier to ask):hmm: StealthV 06-20-05, 05:36 PM Under the front of the car; remove the splash guard under the radiator...I'll email you removal instructions in a few hours. c5racr1 06-20-05, 06:41 PM What is the foam mod? StealthV 06-20-05, 07:19 PM The foam mod per Wienk is to cut away the foam where the shift lever contacts it going into reverse. Taking it a step further, I put the foam in around the shifter and shifted through all the gears. Wherever there was contact between the foam and the shift lever, I cut it out with .........omg, a......... BOXCUTTER. Yes, I'm a terrorist. :shhh: :) thebigjimsho 06-20-05, 07:35 PM lastss, I know you posted before who to contact for the better bushings. For my laziness' sake, could you post that here again? And are the dimensions in the FAQ? lasstss 06-20-05, 09:23 PM lastss, I know you posted before who to contact for the better bushings. For my laziness' sake, could you post that here again? And are the dimensions in the FAQ? Urethane innovators NOrth carolina 252-637-7110 Contact is Lee I paid $25 each for 30 pcs. Good luck | |
