ray01sts
06-18-05, 03:37 AM
I purchased an Autotap over a year ago and I'm going to hook it up while testing out the 96 Fleetwood I'm looking at. I was also wondering if anybody had used one to help solve the lack of instruments on the cluster? I think it will only work with the 96 Fleetwood as it is the only one with OBDII.
davesdeville
06-18-05, 07:10 AM
Info can still be read with OBDI using the proper ... wtf ever that thing is called that I can't think of, scanner or something. If you install a computer, like a laptop or build one for the car, you can use it along with a scanner to display just about any info you can think of on the screen. I don't think just the scanner on its own would be too effective.
ray01sts
06-18-05, 11:52 AM
The Autotap has a virtual dashboard function allowing you to mount a PDA to display RPM, Oil pressure, O2 readings, trans temp, along with several other things.
