leftoverture
06-13-05, 10:49 PM
OK, an electrical mystery for the electrical experts out there. The car is an 83 CDV. I put in a Pioneer DEH2700 head unit. Bought the harness and all the right stuff. After installing, I have a parasitic drain. Now, the harness I bout had a separate little harness for the constant power line which didn't match the plug in the car (the main harness matched fine). So I had to cut the constant plug and wire it direct. I tested both of those wires and the brown one tested as ground. There was a black wire in the main harness that also tested as ground.
So I hooked both the brown wire and the black together to the black ground wire on the stereo. Everything worked but had the drain. So I went back in and cut out the brown wire (had to try something). Everything worked but still had the drain. So tonight I cut the ground wire and put an ammeter in to measure the draw. The stereo was running but showed no amperage draw. Disconnected the meter (possibly to scratch my head http://cadillacforums.com/forums/images/smilies/hmmm.gif) and the stereo was still running. So ground wire not connected and stereo still working. Isn't that impossible?
So I think about it a few moments, and I wonder if it's ground through the antenna lead (power antenna and all). So with stereo power off but key on, I pull the antenna connector out. There seems to still be power to the stereo but the lights all flash. I try to turn the stereo on and the antenna attempts to raise but then doesn't and I lose power to the stereo altogether. Plug the antenna back in and everything works again. So that's how I left it, the black ground wire on the stereo disconnected, the antenna plugged in. The stereo is working, but it will be a couple days before I know if the drain is cured.
Yep, the drain is so low it takes about 3 days to get down far enough for the car to not start. So what do I have happening here? I am sure it has something to do with the stereo, but can someone explain all this to me?
