View Full Version : Blower runs all the time fleetwood350 06-12-05, 08:38 PM Wife's '93 FWB's blower will not shut off. The only way I can get it to stop is to pull the fuse or unplug the harness from the motor. This is , of coursse with the switch off and key removed. Anybody have any ideas??? Thanks!! peteski 06-13-05, 02:18 AM Yes, most likely it is the Blower Power module (shorted out)..
Mine is mounted in the firewall (center, near the blower). That is 93 ELDO.
Peteski fleetwood350 06-13-05, 01:06 PM I found the relay and unplugged it (under the dash pass. side) and it still ran. I will try to locate the module. Is this the same as the resistor that determines speed of blower?? Thanks for the help!!!! fleetwood350 06-13-05, 02:06 PM Peteski, you're right on the money. I found the gizmo, which is under the dash on this car. I have a 91 Olds wagon with the same HVAC system. I plugged the module from the Caddy into the Olds and the blower comes on and will not stop. Will call local dealer and see what a newbie will cost. Might have to go to the bone yard. Many thanks for the great diagnosis!!! peteski 06-13-05, 11:53 PM You're welcome!
It is not a bunch of resistors. It is all electronic (transistorized). But it functions the same as the old resistors did. The power transistor probably shorted out. It happens...
Peteski fleetwood350 06-14-05, 04:29 PM The new one has an external transistor on it. The transistor looks like the one on a Chrysler electronic ignition box. Maybe it will stay cooler and last a while. I read on another website that a blower motor that is pulling too many amps could burn it out. I jumped the fuse terminals with an amp gauge and the motor pulled about 15 amps. Said should be no more than 20, so I guess it is OK. Working for now anyhow!! Redman7 06-24-05, 02:55 PM I am having the same problem. Can anyone tell me where to find this module on a '92 DeVille? Mucho thanks in advance.
Redman7 I need to know the location for this also my 92 deville blower motor run after I turn the car off and remove the key, had to disconnect the wiring harness to the blower motor.
Redman7 91TexasSeville 08-24-05, 02:05 PM For the 89-93 Seville and Eldorado the module is located about center of the firewall on the air plenum. Access is from under the hood. I am not sure about Deville.
I have written about how to change this module what each wire by color does and where it goes. davecv41 09-09-05, 07:17 PM Wife's '93 FWB's blower will not shut off. The only way I can get it to stop is to pull the fuse or unplug the harness from the motor. This is , of coursse with the switch off and key removed. Anybody have any ideas??? Thanks!!
I have a 1995 Fleetwood with the same blower problem, I have not located the module that is mentioned here, can any one help me? 91TexasSeville 09-10-05, 01:11 AM I have a 1995 Fleetwood with the same blower problem, I have not located the module that is mentioned here, can any one help me?
The cars I wrote about were 89-93 Eldorado and Seville only. From 1994 on... there is no separate blower control module, it is located in the blower motor housing. You will need to replace the blower motor assembly. davecv41 09-10-05, 01:36 PM Thanks for the reply, I think the blower is inder the dash.....sounds like big bucks.......davecv41 |
