: Northstar Transplant?
northstar mt
06-11-05, 07:00 PM
I have a 56 Chevy P/U and want to put a V-8 in it . My Uncle had his 99 Deville totalled out and it only has 82000 miles on it and I can have the motor out of it for $500. I have an 02 Seville and love the Northstar. I would love to put this in this truck. What would be involved and what else do I need off the car to make it work? I know it will take quite a bit of fab etc. Any advise would be much appreciated.
davesdeville
06-12-05, 07:25 AM
How much does that truck weigh? The northstar loves to rev but it's not real good for low end torque. So if it's much over 2 tons I'd go for a torque loaded pushrod motor. You might need a reprogrammed OBDI computer or a standalone engine management system since you won't be using the 4T80E. My advice is see if a 500ci Cadillac engine will fit in there... or be boring and use an SBC/BBC.
nota
06-16-05, 08:57 PM
CHRFAB see their web site for hotrod swaps
wireing and CPUs are the biggest mess of work
chevy camaro or small truck v6 [2.8 3.4 0r 3.8] trans auto or stick will bolt up
[with a little grinding]
but sticks need a custom flywheel
not a eazy swap
and costs can go up quickly
capn
06-19-05, 03:21 PM
swapping N*s a great thing, im actually doing the swap into my 1988 RX7, i am going with either a T-5 or a T-56 tranny, but the problem with mounting the N* longitudanly (sp?) is the tranny, the N* just can't pull a numerically low gear like the 6th gear in the T56; i believe you shouldnt go lower then .5 final gear.
but next big thing is the cost of the swap were talking $10,000 easy here you need a custom mounts, driveshaft, and the cost of the engine and tranny, and if you rebuild and make the N* even more potent were talking more money.
mcf1000x2003
06-19-05, 06:10 PM
http://www.cardomain.com/ride/665715 check out this gran prix with a N*
davesdeville
06-19-05, 11:39 PM
A rebuilt N* is around $4k, I can't see a trans costing more than $1500. If you're spending $10k you might be wasting a lot of money somewhere.
nota
06-20-05, 05:32 PM
Custom work adds costs FAST
double what you first think
plus a lot of little stuff adds cost tooo
just wires and aftermarket CPU is $2000
custom flywheels are not cheap
then theres redues as some stuff just willnot work
even proven swaps like chevy V8s cost alot
add unknows in N* swaps and costs go up quickly
davesdeville
06-21-05, 08:40 PM
Again, $2000 for an aftermarket "CPU" is a bit much, because you could use a reprogrammed OBDI computer in most swaps, and even if you did need a complete engine management system they start at around $1500 from CHRFAB.
wawuzat
06-21-05, 09:02 PM
I'm pulling a Y-code N* from my '95 Seville to shoehorn into my Fiero. I'll be keeping the Caddy PCM & all other feeding and/or fed systems, along with the 4T80E transaxle. My Fiero needs a little "umph" since it's already sporting a Ford GT40 MKII body. The aftermarket engine management systems are OK, but not really necessary on the Fiero. I'll fool some of the systems (like ABS & RSS) so the Caddy PCM thinks everything is "normal."
customGTP
06-22-05, 12:17 AM
yeah i got $7000 into mine and i start it up tomorrow.. Msg/Email/AIM me anytime with questions.
pages 14 and 15 are the most recent up to tonight
http://www.cardomain.com/ride/665715/14
http://www.cardomain.com/ride/665715/15
night all
eldorado1
06-22-05, 01:19 PM
night all
Hot damn! Good luck! Even if it just barely catches, this is the fun part!!!!!!!! It's ALIIIIVE!!!!!! http://cadillacforums.com/forums/images/smilies/ego.gif
capn
06-24-05, 12:10 PM
i cant wait to see it up and running!! it will give me hope with my swap:bouncy:
Tom Cramer
08-26-05, 11:28 PM
I have a 93 allante, and I just replaced the radiator, last week for 700 bucks, and it still overheating, it appears that I am pumping exhaust gas into the coolent till it boils out and then heats up.
I'm told that I probably have to replace the engine to the tune of about 8 grand, does that seem about right, for a shop in central calif.? any other ideas before I go the whole route? is that "thermagasket" anything other than snake oil?
Help, I love my allante
Tom
