View Full Version : RWD 5-speeds
Greg55_99
10-29-03, 08:43 PM
The Jeep/Dodge AX15 5-speed, the Jeep NV3550 5-speed, the Toyota R150F & R151F, the 87-92 Toyota Supra Turbo R154 and the Isuzu AR5 5-speed all share the same case to bellhousing bolt pattern. As such there are a number of possibilities that can be had when a 5-speed is desired:
96-99 Dodge Dakota 2.5L bellhousing: Connects all to any Jeep 2.5L L4. Because of it's GM inherited 60 degree bolt pattern, it also works with any Buick FWD V6 and supercharged V6, any Chevrolet 2.8/3.1/3.4 V6, any Cadillac 4.1/4.5/4.9 V8, any Isuzu 3.5/3.5 DOHC V6 and with a minor modification (moving a bolt hole), any Olds Aurora DOHC V8 and Cadillac DOHC Northstar V8.
The R154 out of the 87-93 Supra Turbo is a particularly robust gearbox and is used quite extensively by Australian hot rodders to back up V8 conversions.
http://www.classicconversions.co.uk/r154.htm
Further info: Jeep AX5, Toyota G52/G58, W55, W56, W57 and W58 5-speeds all share a common face pattern on the case. As such, any 88-99 Jeep 2.5L bellhousing (NOT Dakota) will bolt a Toyota W series transmission to a 60 degree GM bolt pattern (and Northstar with the bolt hole mod). The Non Turbo Supra W58 is not as strong as the R154, but is still no slouch.
http://www.classicconversions.co.uk/w55.htm
Greg Williams
elwesso
10-29-03, 09:43 PM
Thats interesting...... Great info......
Got any swaps for a Q45... :D
Greg55_99
11-01-03, 09:40 AM
Well... as a matter of fact...
http://www.rodshop.com.au/bellhousings.htm
Greg
Super Trooper
11-07-03, 08:59 PM
Howdy Gregg
Which vehicle did the AR5 transmission come in?
Can you foot note your data? I don't doubt your integrity, but I'm looking for sources that I can verify.
I need the information for research I'm doing on an Aurora/Northstar swap into an Isuzu Trooper.
Thanks
Bruce
http://myweb.cableone.net/bcanderson/
Greg55_99
11-07-03, 09:25 PM
Howdy Super Trooper,
Follow this whole thread for some info I posted some months back on the Isuzu board:
http://www.4x4wire.com/forums/showflat.php?Cat=&Board=UBB86&Number=327122&Forum=All_Forums&Words=dakota%20bellhousing&Match=Entire%20Phrase&Searchpage=1&Limit=25&Old=6months&Main=327122&Search=true#Post327122
There are some links there you might find of interest. Also, take a look at this pic from the Pirate 4x4 board. It shows both the Wrangler and Dakota bellhousings. They both have the GM 60 degree bolt pattern.
http://www.pirate4x4.com/forum/showthread.php?s=&threadid=181361&highlight=ax15+bellhousing
Greg
Super Trooper
11-07-03, 10:09 PM
AAAAAAAAAAAAHHHHHHHHHHHHHHHHHHHH you posted to Isuzu forum and I missed it??? Ratz
Hey thanks for the help!
Bruce
