View Full Version : Power Steering Pump Growl
Vendor
10-28-03, 11:36 PM
I recently purchased an 89 Seville in excellent condition. The only major complaint is a noisy power steering pump during acceleration. A new after-marked did not improve the noise. Any suggestions, or is this typical for this modle?
Also trying to get the correct switch settings for the Seville garage door opener. Again, any suggestions?
Thanks for help on either of these,
Vendor
elwesso
10-29-03, 04:13 PM
Start the engine, and let it run for a minute or so.... Shut it off, and look in the PS resovoir..... Do you see bubbles....
If so, you got air in the system...... You'll have to do the bleed procedure, which I can post if you need it!!!
