View Full Version : Attention:...........91TEXASSEVILLE::::::::::::
clusco
06-05-05, 01:39 PM
In a previous post about my A/C that I was trying to receive help on named, "Need Help---> A/C Compressor Not Kicking On!". After I stated that I couldn't trip my compressor on through the low side cutoff plug so instead I tripped it on through the relay in the fuse box, you made the statement that I very likely blew a ciruit or a relay doin this. Now my question to you is why won't my system allow the compressor to be jumped through the low side cutoff switch plug? And I am getting the code A012 in my display. I looked up the code and it says that A012 is...."Low Side Temperature Sensor Circuit". Could this code mean that I did something to the fuse box relay OR could it mean that the plug and harness running from the compressor to the low side cutoff switch has gone bad? And if you think perhaps this plug has gone bad, how big of a job is it to run a new harness? I looked and it doesn't look good. Anyone, give me some ideas please. Thanks
Less2
06-10-05, 12:39 AM
:hmm: hello i ha the same syptom i cleared the a/c code and added a one can quick
charge of 134a from the part's store and she still getting cold in dallas tx
a small amount of freon has leaked out and activatived your code and system
won't reset until the code is cleared thru onboard message center or tech scanner:hmm:
