View Full Version : Coughing problem
rnunez76
06-04-05, 10:02 PM
Hey Im having a bit of a problem. I was doing a tune-up on a 1992 seville, replaced the spark plugs and wires, air filter and fuel filter. Well when I was replacing the wires(Bosche) , they didn't match exactly as the ones previously on there. So I went ahead and put the plugs according to the length of the wires to the distance from the distributor. When I was pulling of one of the wires from the distributor, I bent a tip of the distr. cap. Well When I was driving the car it started to cough and then it would shut off. I can get it to drive for a little while but then all of a sudden it shuts off again and I get a code E032. Where did I go wrong? How do I know for sure which wires go where? What should I do? :banghead:
clusco
06-04-05, 10:19 PM
EO32 :................................................. ......Open MAP Sensor Signal
Ranger
06-04-05, 10:33 PM
Did you remove and replace the wires one at a time? Please tell me you didn't remove them all and then replace them by length with no regard to firing order.
How do you "bend the tip of the distributor cap"?
rnunez76
06-05-05, 02:32 PM
I did not just pull them off. I bent the tip while trying to to take of the cable from the distributor. Do I have the firing order correct?
From front of car:
2 4 6 8
1 3 5 7
rnunez76
06-05-05, 02:33 PM
I got this far. But I do not know what this means. It was working fine before I did the tune-up. Where is this MAP Sensor?
rnunez76
06-06-05, 05:11 PM
Anybody have any ideas?
Ranger
06-06-05, 07:04 PM
From front of car:
2 4 6 8
1 3 5 7
Well, I assume you mean you bent the tip of the wire., I don't think you can bend the tip of the cap. You'll break it first.
What you listed above is the cylinder layout not the firing order. Firing order is 18436572.
rnunez76
06-06-05, 08:24 PM
Sorry, I meant to say cylinder layout. So what can you tell me about the MAP sensor error? :banghead:
Ranger
06-06-05, 09:39 PM
Not too much. Sounds like maybe a bad sensor.
rnunez76
06-07-05, 12:22 AM
Well can anyone tell me what this sensor looks like and where to find it?
