FunkyPizzaMan
06-03-05, 08:58 AM
The Victim:
A Grey & Black 1983 Cadillac Seville, In excellent condition. It's the ultimate luxury car, I love the solid american steel and beastly size. Best of all: The seats are so big & comfortable! The previous owner garaged it after about 40,000 miles in the mid 80's, and was driven less than 1,500 miles until 1998, when it came into my possession. It runs smoothly, and has not needed any work. However, I do Have one major problem with this car. It's Horribly UnderPowered! And so, I'm going to attempt to correct this blaring defect. Acceleration to 60 MPH can take as long as 15 seconds, And It's never topped 100MPH. I would like a 0-60 time of more like 10 seconds; with a maximum speed of, hopefully, 130+ MPH.
And the opportunity may have just appeared.
So, heres the deal:
I've been offered A Chevrolet LT-1 Engine and the stock transmission to which it was mated, for a mere 450$. The Engine+Tranny were recentely pulled from A Co-workers 1993 Z28 Camaro. It's in very good condition, was used for about 57,000 miles, and has never needed repair. It has seen some heavy use, however, from the owners occassional drag racing.
Alright, So My Question Is:
Can An LT-1 Engine & Transmission be mounted In A 1983 Seville? Yes? No? PLEASE respond as to Why, or Why Not. I would like to research all aspects of this project. If either the Engine or Transmission can be used, then which? if the engine is compatible, but the transmission is not, what transmissions are compatible with both the 1983 seville's mounts and the 350Ci LT1 engine? If the engine is unusable, but the transmission is, do any other engines exhist that are compatible with both the transmission and the car's engine mounts?
Also, I Am willing to make modifications to the body in order accomidate this combo. The tranny is A manual, I believe, but even so, I would have no problem cutting A compartment in the floor for A shifter. Can the engine compartment be modified to accept this engine? If so, What kind of changes would be needed? And also with the transmission, what changes would be needed to mount it? I would not mind replacing the exhaust, fuel, and drivetrain systems to comply with the LT1. As for tires, can you recommend any good tires made for high performance vehicles?
Thank You For Your Time,
-Bryn Smith
So, heres the deal:
-Bryn Smith
