Dan_Deville
05-31-05, 04:53 PM
I have a 1997 Deville with about 93,000 on it. It recently started running like it's not getting gas when I am in drive. In park the engine will rev up fine but in neutral and drive, when I give it gas it brings the rpms down insted of bringing them up. It started out just doing it once in a while but now it will hardly drive. It also seems to be worse when i am going uphill. Any suggestions would be greatly appreciated.
Yeah, I'd put a fuel pressure guage on it and see what the fuel pressure does under those conditions.
champstang
06-09-05, 01:20 PM
I had the same problem on my 97 deville. I changed the fuel pressure regulator, about 60.00, you can even change it yourself, and mine is working fine now.
smoooth
06-12-05, 11:45 PM
hey i gotta 91 deville and i was wondering what the fuel pressure should be? i appreciate any help. not sure if the pump or regulator is out...
45-50 psi as well as I can recall.
smoooth
06-13-05, 08:53 PM
Thank you very much for the information I will check it out
