View Full Version : CTS's built-in garage door opener:
pkx
02-16-03, 01:51 PM
Does anyone know if the Caddy CTS's built-in garage door opener is compatible with Genie Intellicode opening systems?
Thanks!
*Placed in other forum sections since this is a Cadillac accessory not specific to CTS. Other Cadillac owners may have the answer, but not read the CTS section - HotRodSaint*
elwesso
02-22-03, 09:42 AM
Are you talking about the rolling codes??? I am not fo sho, but I think it is. Have you tried programming it? The instructions are in the owners manual.
I think it is the "homelink" brand, and you can check with the garage door openers owners manual (if there is such a thing), and see if it is compatible. I know it doesnt work with mine, but i have an old school genie.
If I remember correctly, the way you program it is hold the outer 2 buttons, and hold the opener a few inches from the buttons. When the little light blinks, then let go of it and it should be programmed. Youll have to check on that one, but that I am pretty sure.
Maximln
02-22-03, 08:43 PM
With a rolling code system, there are a couple of extra steps. Once you program as previously described, you have to go inside your garage and look for the "training" or "program" button on the back of your garage opener. It is sometimes behind a removeable panel. There is also usually a little light that will come after you push the button which means that it is "learning" mode. Once you do this, you have to go back to your car and press the button that was previously programmed by you for a few seconds so your garage unit will "learn" the signal. The little light by the garage buttons in your car should flash rapidly for a few seconds and then shine steady when pushing the button. After a few seconds, release the button and then push it again. Your garage door should now be moving up or down.
If you have any additional problems, let me know. I haven't met a UGO that I couldn't get programmed yet!
Max
