View Full Version : 95 deville
pntbll687
05-30-05, 12:12 AM
What size are the speakers in the front doors and under the back deck? I'm looking to get new ones but don't know what size to get. Thanx for the help.
Kdirk
05-31-05, 11:02 AM
Hi,
Rear deck are 6x9's, but the factory speakers are snap in mounting (no existing screw holes). You'll have to drill the sheet metal at the four "corners" of each speaker and install speed clips with self tapping screws or use machine screws and nuts (preferable as these will be less likely to rattle). The front doors are two component speakers - woofers are 5 1/4" (i'm pretty sure - maybe 5", make sure you get shallow drivers or they'll interfere with the bottom edge of the window) and the separate tweeters are custom mount (if you get aftermarket expect to do some fabrication to get them into the door panel)
I did these in my 95 SDV, and it was a job. The rear deck was probably worst, having to drill it and clean up all the shavings. Of course, the whole back seat and rear deck trim panel has to be removed as well.
Best of luck!
Kevin
