View Full Version : Engine knocking or pinging
upstate
05-28-05, 06:33 PM
I just bought my second 91 Coupe Deville Spring time and I filled her yesterday with 91 0ctane Sunoco. Now when I give it the gas I get the pinging like I used cheap gas. Could it just been a load of bad gas or is there something else that can cause this sensation?:hmm:
Ranger
05-28-05, 09:43 PM
I'd start by checking the base timing and the EGR valve.
upstate
05-28-05, 10:12 PM
Thanks I will do that. When you say base timing is that the same as timing the engine, what we used to do in the old days?
Ranger
05-29-05, 01:11 PM
Kinda. I forget exactly how on the 4.9 so hopefully some one will chime in but if I remember correctly you have to unplug a green connector at the distributor to disconnect the PCM inputs, then set the base timing (like the old days). Wait for someone to confirm this if you don't have a service manual.
bharner
05-31-05, 12:56 PM
I think you have to jump terminals A & B on that connector under the dash. That will set it to timming mode. Once there get ur light out and a 15mm wrench. Loosen the distrb. hold down bolt. Search on it under the HT4100/4.9 section. Should be 10* BTC. Unless "base timing" is something else. If it is then wat is it?
C Rich
06-01-05, 12:15 AM
also note alot of pings and knocks can be caused simply by low oil levels
Ranger
06-01-05, 12:21 AM
If you are getting knocking because of low oil levels, you have bigger problems to worry about.
