View Full Version : Reduced Stability message
Devil_concours
02-14-03, 09:26 AM
I keep getting "reduced stability vehicle speed limited to 90mph" How do i get that fixed. BTW car does go over 90.
kcnewell
02-14-03, 08:03 PM
I don't know about the message you're getting....But I'll take it as a compliment that you're using my line as you're sig. line!
the Sandman
02-14-03, 08:19 PM
If the EBTCM ( electronic brake and traction control module) detects an electrical fault in the stability
control system, STABILITY REDUCED is displayed in the DIC.
See details here. (http://www.cadillacforums.com/suspension.pdf)
There should be a code set in the computer which will help pinpoint the fault.
Devil_concours
02-14-03, 10:58 PM
it seems like my brake pads need to be changed other than that i don't see why the message is coming up.
the Sandman
02-16-03, 02:33 PM
Originally posted by Devil_concours
it seems like my brake pads need to be changed other than that i don't see why the message is coming up. Have you checked for a code stored in the computer? The "Reduced Stability" message signifies an electrical fault in the system - damaged wire, sensor or module.
