View Full Version : Wiring diagram
Dadillac
05-22-05, 11:27 AM
If anyone has a stereo wiring diagram for a '02 Seville SLS, can you please post it here, or e-mail it to me? I am installing an aftermarket unit, and need to know what the factory wiring entails. Or, if someone can lead me to a website, where I can view this info, it would be greatly appreciated. Thanks
Don
Hairball
11-22-10, 10:12 AM
Did you ever find one? If so, could you share it with me? I have a 93 Seville and need to rewire the entire aftermarket stereo that someone put it using nothing but electrical tape! They had it wired so wrong the left speakers don't work, the power antenna isn't hooked up, and all the factory harnesses are cut. I found 2 diagrams for the 93 Seville but they are both incorrect. This is what they show:
Battery Constant 12v: Orange
Accessory Switched 12v: Yellow
Ground: Black
Illumination: Gray
Dimmer: Gray/Black
Antenna Trigger: Pink
Left Front Speaker Positive (+): Tan
Left Front Speaker Negative (-): Gray
Right Front Speaker Positive (+): Light Green
Right Front Speaker Negative (-): Dark Green
Left Rear Speaker Positive (+): Brown
Left Rear Speaker Negative (-): Yellow
Right Rear Speaker Positive (+): Dark Blue
Right Rear Speaker Negative (-): Light Blue
But this is NOT what mine are! The only ones I have for sure are blue ones. I did find the factory power, ground, and memory wires but nothing else. There is no pink wire, there are 3 gray wires, and several yellows, etc. Things just aren't adding up. Thanks.
