View Full Version : Autotap software on sale!
tbyrne
05-17-05, 03:37 PM
The AutoTap scan tool connects the special OBD II plug-in-port on or under the dash of your car or light truck to your computer. The AutoTap scanner then translates the signals from your vehicle?s computer-controlled sensors to easy-to-read visual displays.
Did you know that your car provides data for hundreds of sensor readings? Just choose which of these parameters you want to see and whether you want to view them in tables or as graphs, meters or gauges. Set your own ranges and alarms and even pick your own colors! Once you've got a screen configuration that works for you, save it with a couple of keystrokes. Save as many different screen configurations as you need... for different vehicles, or perhaps one for major maintenance, one for tuning, one for quick checks at the track. Now you?ve got a powerful tool that will allow you to read many different parameters.
Track quick-changing parameters like RPM and O2 Sensor readings at rates up to 40 times a second. View your results in English or Metric
Log a dyno or track run with AutoTap?s proprietary data logging feature. Then replay the file to review your vehicle?s performance; transfer it to a spreadsheet for analysis; or email it to a friend to compare your performance to his.
Turn off the Check Engine light. Did you know something as simple as a loose gas cap can make your trouble light come on? Use the AutoTap scanner to retrieve trouble codes and their descriptions and reset your Check Engine light. You might just save big bucks by avoiding a trip to the dealer!
We are offering a 5% discount and free shipping (48 states) for orders that are placed through Sunday evening (5/22)
Orders can be placed online or by calling 1-877-4-TBYRNE.(1-877-482-9763).
Have a good day!
