View Full Version : Test fitted my 26's - They Rub - With Pics - Any Advice? Tom-Lade 05-12-05, 03:17 AM I test fitted my 26" Dub Esinem floaters and they fit fine in the back but up front they rub on the inner wheel well plastic. When turning left, on the left front it rubs right where the e-brake line is behind the plastic. I think if I can move that plastic back .5-1" I should be alright, except that damn ebrake line is right behind it. So I need to relocate it or something. It's not on the right side, so that should be okay.
Does anyone have any advice for getting these 26's to fit or advice on how to relocate the ebrake line?
Tom Boombotz 05-12-05, 07:58 AM Have no advice, but would love to know how rough the ride is once you get them on? Just having 22's change the ride quite a bit. Couldn't imagine 26's. frankiext 05-12-05, 11:21 AM My wheels/tires rubbed same spot, took EXT to Martin Cadillac
in NJ and they "fixed" it. They do this stuff all the time.
Perfect now. Tom-Lade 05-12-05, 01:36 PM Frankie, can you tell me what 'fixed' it means? Did they re-route the brake line or remove all the plastic. Any chance you can get some pics of the 'fix'? Problem is, here in WA, no one has 26's. So i'm like a pioneer, no custom shops have ever tried this that I've found in my area.
26's will ride just fine. I've had 22's before and they are no different than stock, other than a little wheel shake at 65mph. It cracks me up when people get all concerned over the ride of big rims, potholes, if they'll last, etc. It's all a myth. Don't curb them and you'll think you're just skating on stockers. brett79 05-12-05, 01:52 PM Frankie, can you tell me what 'fixed' It cracks me up when people get all concerned over the ride of big rims, potholes, if they'll last, etc. It's all a myth. Don't curb them and you'll think you're just skating on stockers.
:cookoo: there is definitely a difference, you may not notice it, but others do... frankiext 05-12-05, 04:00 PM Will take some pics and ask them what they did. My wheels
are only 22' but because they were 10s they rubbed on
back of front wheel wells and on top of wells on bumps.
They definitely carved some plastic out. 04SilverEXT 05-12-05, 05:23 PM Hey tom, I got some 24" dub bellagios and they rubbed but cadillac fixed it for me no problem...just cut out the plastic where its rubbing, keep cutting a little bit at a time until you see that its not touching anymore...the line wont get hit from the rim, so no worries there, all you have to do is clip it a little at a time and u may also want to clip the front bumper corners to keep it from rubbing... Tom-Lade 05-12-05, 10:52 PM That plastic is very thin, I don't see how cutting it will stop it from rubbing. It needs to be pulled back an 1" if possible to give a little extra room. I think it can be done, but again that damn ebrake line needs to be moved. These are 10" wide rims by the way. I'm just wondering what other people with 26's do. I'm certainly not the first to have this problem. How many people on this forum have Escalades with 26's? When I bought my cadillac from bellevue they fixed the rubbing problem with my 24's. I do not know if it was as extensive as yours but they can fix it there. Tom-Lade 05-12-05, 11:27 PM I can do the work, I'm just looking for real life examples with details of how the problem can be fixed. stevedinha01 05-12-05, 11:41 PM i have 26's and i trimmed the corners of the front bumpers and trimmed the inner fender plastic. thats all blingblingcv 05-13-05, 12:44 AM My wheels/tires rubbed same spot, took EXT to Martin Cadillac
Perfect now.
Frankie I am also from NJ where are you from? Tom-Lade 05-13-05, 12:58 AM Steve, do you have any pics of what you trimmed? How much of the inner fender plastic were you able to trim? Why'd you trim your bumpers, I didnt see that being a problem. Doesn't it look like shit cutting that finished plastic? slimm44 05-13-05, 01:10 AM if its an awd, you can just crank the torsion bars a lil and get an alignment. pimp-cadi-danny 05-13-05, 07:54 PM i went from 22's to 24's and i dont rub at all Tom-Lade 05-14-05, 01:31 AM I tested fitted the front again and this time I released the ebrake line and removed all the plastic and it doesn't rub at all. It's still CLOSE, but would only rub if I hit a big bump. I think I will reroute the ebrake line out of the way, cut part of the inner wheel well plastic out of the way, trim the inner fender plastic, and zip tie the inner wheel well plastic back and also the washer fluid tank forward and it should be alright.
I'm hoping to get all four on tomorrow. I'll post pics if it works out. 04SilverEXT 05-14-05, 09:53 AM I tested fitted the front again and this time I released the ebrake line and removed all the plastic and it doesn't rub at all. It's still CLOSE, but would only rub if I hit a big bump. I think I will reroute the ebrake line out of the way, cut part of the inner wheel well plastic out of the way, trim the inner fender plastic, and zip tie the inner wheel well plastic back and also the washer fluid tank forward and it should be alright.
your doing entirly too much work for nothing...all you have to do is cut the plastic and trim the corners of the bumpers...its simple...there is no need to move the washer fluid or e brake line....just trim the plastic and you will see that its fine... Tom-Lade 05-14-05, 12:14 PM Its not that much work. I'm zip tieing the washer tank forward, takes 30 seconds. Rerouting the ebrake line (already done) took 15 minutes to unhook/reroute. But i'm not trimming my bumper at all. I imagine cutting into the finished plastic will make it look like shit. You did that and it didnt mess it all up? RaGzEmCeE 05-14-05, 12:51 PM [QUOTE=Tom-Lade] Problem is, here in WA, no one has 26's. So i'm like a pioneer, no custom shops have ever tried this that I've found in my area.
QUOTE]
damn lol down in LA if your rolling on anything under 24s most people dont even look ..... i see 26's and 28's a lot .... but as far as the rubbing i had my installer trim a lil bit 04SilverEXT 05-14-05, 01:09 PM Its not that much work. I'm zip tieing the washer tank forward, takes 30 seconds. Rerouting the ebrake line (already done) took 15 minutes to unhook/reroute. But i'm not trimming my bumper at all. I imagine cutting into the finished plastic will make it look like shit. You did that and it didnt mess it all up?
hey, its only the tip on the inside of the front bumper...if you looked at my truck and I didnt say anything, you wouldnt even notice...anyway, who did u get the rims from? slimm44 05-14-05, 09:28 PM Problem is, here in WA, no one has 26's. So i'm like a pioneer, no custom shops have ever tried this that I've found in my area.
yep. washington is a few years behind places like cali, ny, and miami in customizing. things that are really played out there are just starting to show up here. Tom-Lade 05-15-05, 02:01 PM I got the 26's on, I'll get pics today. So far no rubbing and they look sick. 04SilverEXT 05-15-05, 04:29 PM lets see some pics... ccleve76 05-16-05, 07:48 PM here's pic's of my escalade on 26's http://www.cardomain.com/id/ccleve76 they rub a little when i turn hard left and rite, and when going over speed bumps, but nothing serious, ride is still excellent for most part, untill i hit beep pot holes..lol | |
