: Temperature problem???
10-22-03, 08:59 PM
Is my car running too hot?. Today i was on the highway and checked the temp it was 217* F . Is that too hot or thats the normal temp thanks in advance.
10-22-03, 09:05 PM
I keep seeing people post temperatures here.. how do you find it out? I have a 99 sts and it has an analog temperature gauge.. is there ssome way to find the actual temp?
10-22-03, 09:38 PM
Well, 210 is considered optimum, so if it was hot out, 217 sounds fine. Check your coolant levels though while you're on it, make sure you're properly filled.
10-23-03, 05:44 AM
That's a NORMAL temp.
12-20-03, 12:35 AM
My 96 Deville was running at 220-231 over the summer. It was about 100-110 outside-I called my local Cadillac dealer and they said 200-240 was normal running temp. Anything under 240 is fine according to them.
