AllenPacla
05-09-05, 03:24 AM
I noticed that only half of my brake lights illuminate when i step on the brake. After thumping the strip brake lights, sometimes it all light up. Is this repairable? I mean, is it just a loose connection somewhere, perhaps a good soldering will solve? Has anyone had this experience. How about replacement? Are they even available online?
Vesicant
05-09-05, 05:06 PM
Talk to Logandiagnostic on the forums here...He rebuilds and replaces lights like the Catera's.
chregan
05-09-05, 05:24 PM
You can test the various plugs by applying 12V to them. Use a battery charger or even jumper cables from the battery.
mrman88
05-10-05, 05:16 PM
Just as a suggestion. Its spelled Brake
AllenPacla
05-10-05, 07:31 PM
Well, i tried to edit the title but i was only able to edit the message body. So i just left it at that. I guess you didn't read the post, just the title.
AllenPacla
05-10-05, 07:33 PM
And about the strip light on top of the back compartment, i tried to remove it but after i did, i found out that it's a sealed type and there is no way i can get inside it unless i break something. I guess, i'll just have to let it be for now, until the time i buy a new one.
Vesicant
05-10-05, 07:42 PM
Did you contact Logan?
(fixed the thread name for you btw)
AllenPacla
05-10-05, 10:12 PM
thanks for fixing it Jeff. I haven't contacted Logan yet, i'll get in touch with them as soon as i can. So far, I have tried re-assembling the strip light back and tighten the screws a little and it seems to be holding. The only problem is that occassionally, when tapped, the lights will again only have half way illuminated. I am trying to budget my expenses on this car to the most necessary to the least. I still am solving the Secondary Air Injection error code. I have ordered some replacement parts and hopefully it works. Thanks again Jeff.
AllenPacla
05-11-05, 10:14 PM
Guess what? I decided to give it a go, I mean, rebuilt the strip brake light myself. And I am glad i did. I saved myself another $110. Luckily, only the wires that connects the three board together are loose. I soldered them anew and voila! I contacted Logandiagnostics and they quoted me that price for the Catera's strip brake lights. And it made me think, if they are just rebuilding it, then why don't i try it myself. If i break anything beyond repair then i will go and buy one from them. It paid off, I am just sealing the assembly as of this writing and four more hours and i will assemble it back. Thanks Jeff.
