View Full Version : Header flange gasket question?
willsctsv
05-05-05, 10:25 PM
Just put the B&B's on the other day, The flange from the exhaust to the Cats, did not fit flush, I thought with the gasket and tightening the bolts it would pull together. NOT! Burned a section of gasket out and had an exhaust leak that made the V sound like shit!:helpless:
So, I could not get that size gasket from the auto parts store I figure I'll call B&B to send some new ones. In the mean time I have Watkins Glen on Monday and can't drive all the way there with this leak. :rant2:
I tried to sandwich the old burned out gasket with 2 paper gaskets that I cut out of a sheet and coated them with Indian head. :hmm:
In addition I was able to get a better more flush fit with the help of a mini sledge hammer.:bonkers:
It lasted 2 days and now it sounds like shit again.:rant2:
Does any one have any suggestions for some kind of sealer I can use as a temporary fix. It needs to withstand alot of heat, being so close to the Cat's?
StealthV
05-05-05, 11:09 PM
Ultra copper high temp silicone should get you by until the new gaskets show up.
StealthV
05-05-05, 11:11 PM
http://www.permatex.com/motorcycle/RecProd.asp?f_call=get_item&item_no=81878
http://www.permatex.com/images/catalog/gaskets/81878.jpg
ssmith100
05-05-05, 11:14 PM
Yep, just like Rick said. iIwas noticing the flanges were my B&B mounts to the factory manifolds and the flanges are really bent. Going to take some "bending" and some high temp copper silicone to take care of it.
Shane
willsctsv
05-06-05, 08:19 AM
Thanks Rick, Do you recommend using the Silicone with the new gaskets also?
