View Full Version : Preliminary Specs for 2004 Cadllac XLR
the Sandman
02-12-03, 01:26 PM
---General---
Driven Wheels: RWD
---Engine---
Configuration: V
Cylinders: 8
Displacement (cc): 4565
Bhp@RPM: 315 @ 6400
Torque (lb.-ft.)@RPM: 310 @ 4000
Valve Gear: DOHC
Block Material: aluminum
Head Material: aluminum
Bore X Stroke (mm): 93 x 84
Comp. Ratio: 10.5:1
Fuel System: sequential electronic fuel injection
---Transmission---
Type: Automatic
# Gears (excl Rev): 5
Reverse Gear Ratio: 3.02
Final Drive Ratio: 2.93
---Steering---
Type: rack-and-pinion
Steering Ratio: 17.2:1
Turning Circle (ft): 39
---Suspension---
Type - Front: Double A-arm
Type - Rear: Double A-arm
---Wheels/Tires---
Speed Rating: Z
Tire Size F/R: 235/50R18
Whl. Size (in.)/Type F/R: 18 inch
---Brakes---
Type - Front: Disc
Type - Rear: Disc
Fr. Diameter (in.): 12.8
Rr. Diameter (in.): 12.0
ABS: Std
Stability Control: Std
---Capacities---
Fuel Capacity (gallons): 18.0
Oil Capacity (qts.): 10
---Vehicle Dimensions---
Curb Weight (lbs.): 3645
Front Track (in.): 62.2
Rear Track (in.): 62.2
Height (in.): 50.4
Length (in.): 177.7
Wheelbase (in.): 105.7
Width (in.): 72.3
Ground Clear. (in.): 6.61
---Interior Specs---
Head Rm F (in.): 37.6
Shlder Rm F (in.): 54.3
Hip Room F (in.): 53
Leg Room F (in.): 35.1
Cargo Volume (cu. ft.): 11.6
Fuel Economy
EPA Hwy (mpg): 28
EPA City (mpg): 18
---Performance---
0-60 mph (sec.): 5.9 (mfg)
