View Full Version : Oil around Spark plugs
Donchek
05-01-05, 09:31 PM
Does anybody know if it is normal that when you pull the spark plug connectors out and look inside the engine, the spark plug is emersed in a pool of oil.
I appreciate any info. I'm a new catera owner and so far i have fixed the oil cooler problem myself.
Vesicant
05-01-05, 09:55 PM
No not normal - sounds like either a bad valve cover or a valve cover gasket. Get this checked out before it destroys the plug or plugwire and starts misfiring.
inconnu
05-02-05, 12:44 PM
Had the same problem and i got the gaskets changed about a month ago but today i when i pulled the spark plug boots it was the same old story and i wont spend money on valve covers even looked at after throwing 500 bucks down the drain but i wish you better luck though
