View Full Version : 2000 DeVille Waterpump
akhris
05-01-05, 01:58 PM
Im looking for information on changing the waterpump on a 2000 DeVille, if anyone knows of a guide, or would be kind enough to outline the process here, I would be greatly appreciative.
Ranger
05-01-05, 06:44 PM
Disengage the water pump drive belt.
Remove the pump cover.
Use water pump cartridge removal tool to loosen cartridge. It is not threaded (cam locked). It only takes about 1/8 turn clockwise to loosen.
Reverse the instalation.
cadi197
05-03-05, 01:12 PM
I saw on ebay, you can buy the gm toom for the removal and installation of the Northstar water pump. It is made by lisle and runs about $20-$25
Ranger
05-03-05, 09:24 PM
The Lysle socket is stamped steel (heavy guage sheet metal), that's why it is so cheap. I have heard some people say they had trouble with it. Other said it worked fine. A machined socket from Snap-on runs about $75 but is much beefier. You can rent one from caddyinfo http://www.caddyinfo.com/toolrental.htm. here is a picture of one I made but haven't needed.........yet. http://www.geocities.com/grandolfo/
brougham
05-04-05, 02:25 PM
If you need any more information then this do a search. There are a lot of posts here about it.
