jupiter57
04-28-05, 01:38 PM
I now am a victim of the dreaded “Overheat”. ’97 Deville, 4.6 N*
I have extensively searched and read every thread here that mentions anything at all about the cooling system or overheating, but alas, I am left “uneducated”.
It started last Wednesday afternoon, driving the X-way home from work, went about 25 miles when suddenly got the “Turn of A/C” message, I knew from reading here what was happening. I slowed from 75 to 60 mph but the temp kept climbing and messages appearing. When it got to 260 , I pulled over. Of course coolant was coming out the overflow.
I let her cool down long enough to get the cap off and had to add about ½ gal Dex-Cool mix. Started her up, checked the coolant level and went on my way. About 6-8 miles further, I again got the “Turn off A/C” message as I was exiting the X-way, temp started falling as I coasted up the ramp and was down to around 235 and falling so I easily drove the remaining 9 miles to my house while the temp fell to the usual 203- 217 degree readings.
When I popped the hood to check it out, I noticed that the water pump belt was quite stretched to where the tensioner was nearly bottomed out. I parked it then and went under the hood on Saturday after picking up some more Dex-Cool, distilled water, new Thermostat & gaskets, new belt, new water pump, and Bars Leaks powder (2 tubes).
Drained out all the old coolant, checked the water pump, (quite snug with no play, not too tight but did not spin too easily either. Only slightly less tight than a new one I have, so I didn't replace it), installed new belt, checked and put a drop of oil on tensioner, being careful not to get any oil on the pulleys and belt, and installed the new thermostat. I then proceeded to flush the block and the radiator. Old coolant from block was fairly clean BUT, when I put the water hose in the upper radiator hose, it seemed that the water from my hose didn’t flow as easily as I thought it should, the stream out was very weak. I then proceeded to back flush through the lower hose and still it seemed the flow just wasn’t as good as I thought it should be.
I then proceeded to blow all water out of the block and radiator with compressed air (<15 lbs.) on one end and a Shop Vac on the other. Then a refill with 50/50 Dex-Cool and distilled water, two tubes of Bars Leak, new belt, then did the usual routine of letting engine come up to temp and topping out the tank, let it cool down then a test drive and again topped off the pressure tank.
The temps on the dash seemed to be all over the place while driving in town(but not over 227 degrees) so I parked it for the night. Next morning I checked the tank, still full with a slight vacuum on the cap when removing it.
I then proceeded to start the engine and quickly check for air bubbles in the tank, only one good burp on startup, with no sign whatsoever of ANY bubbles all the way up to operating temp (197 Degrees), temps stabilized while driving around town.
No sign of water in the oil nor oil in the coolant, however, when I put it back on the interstate the next day at 65 MPH, temp got up to 240 degrees in 12 miles before I shut it down. Coolant was splashed out of the overflow hose. Let it cool down, topped off the tank and proceeded home on the highway at 55 MPH, went about 6 miles then before temp climbed back to 240, again shut it off, topped the tank and made it the rest of the way home.
I have an appointment on Saturday to have the radiator “Boiled out”, and “Rodded” by my local radiator shop, along with a pressure test of my cooling system, they do great quality work! I hope this will solve the problem as I have read here that a clogged radiator could cause overheating at highway speeds.
Anyone think the radator is my problem?
I really don’t believe and this point it is the Head gasket(s), even though she has 195K on the clock, she was religiously maintained at the Dealer by the lady who previously owned it. Not sure how the coolant was maintained, but it was a proper 50/50 mix and, like the rest of the car, it was clean as a pin!
Any ideas guys?
Anyone else had these symptoms? How did you fix it?
Any ideas guys?
