I~LUV~Caddys8792
04-27-05, 09:14 PM
I was curious if the 1991-93 Devilles have a limited slip differential or is it an open differential? I was curious because the 4.9 has a lot of torque to put through FWD and some manufacturers use a limited slip differential in FWD with high power (Nissan Sentra SE-R Spec V and Dodge SRT-4 come to mind)
No. It doesn't have a differential.
It does have a diff. It is in the passenger side deep inside near where the pass side axle comes out. just not like a rear wheel drive diff
Talk to Thrasher Engineering, they have a posi unit that is deisgned around the 4T60E for the SC 3800 Grand Prix.
Skullman
04-27-05, 11:30 PM
~ No Diff!? How does it move?
Skullman {:{}
It has a "transaxle" (transmission and differential combo). If you look under there, you won't see the conventional differential. Not sure when they switched. I recall my '85 Eldo still had one. I could be wrong but I don't believe the transaxle is "posi".
DeVillish
04-28-05, 03:30 PM
its not, its a one wheel wonder. There used to be a site(they had an add on here) that sold posi type diffs for these cars.
