Twilightcall
04-27-05, 03:58 PM
Ok guys I need your help in finding what is wrong with my 1996 Deville.
It is a 1996 Deville with N* with 96K miles. The problem is that it seems to stay in 2nd gear and never shifts. I know what you are thinking Shift Soleniods, right? Please read on.
Now I have changed shift soleniods before, it was on my 94 Concours and it worked fine afterward.
Now is where it gets strange. I have not once received any codes or the CEL light to come on. The problem acts just like my 94 did when it was shift soleniods. However, my 1996 has no had the Check Engine Light come on. Normally, in my experience the shift solenoids would trigger the CEL. Since I am not getting a CEL light could it still be the solenoids causing it not to shift?
Is there anything else that could cause it not to shift? Should I remove the pan and check for V at the solenoids? What should the V be and where to check on the SS harness? I am just not sure where to go since it acts like shift solenoids but won't send out a code. I would greatly appreciate any help on this matter.
