ReagansRollsRoyce
04-26-05, 01:05 AM
Really odd noise has started of late behind my spedometer. It occurs when the needle is above 33 mph. It either is a repetitive noise that sounds like brushing teeth (swish-swish-swish-swish-swish) or a repetitive squeak (eep-eep-eep-eep) that follows the spedometer.
My dad thought it might be that the spedometer cable was out of "grease" so he had me back up the car really fast a couple of times to "reverse the spedometer cable" and he thought that might "dip it into some of the grease if there was any left" (he is not a mechanic, nor am I so if you are rolling on the floor my feelings are not hurt ;) )
This procedure actually worked...once, or perhaps it stopped by lucky coincidence. However, today, it is back, eep-eep-eep. It totally ruins the quiet ride of the cadillac because it is right there, squeaking away behind the spedometer. Very irritating. Hitting the dashboard did not work either.
Any idea what it is? My dad says he thinks i'll just have to have a new cable put in. It's so bizarre. I was thinking maybe I could stick a can of WD-40 thru that little hole where the button to set the trip meter is and see if I could get some grease in that way (if that is actually the problem) but I sure don't want to do that unless its okay.
