View Full Version : EAS49 error, Check Engine 94 fleetwood
nphoenix
04-22-05, 03:10 AM
I get a Check engine light whenever the secondary electric cooling fans come on. I also unplugged the fan, and it still gave em the check engine at same time.
There is no EAS 49 code in my caddy shop manual.
I used a scan tool to read the code.
Katshot
04-22-05, 03:05 PM
Probably a bad relay. I'd try reading the OBD codes via the basic "Off & Warmer" button push method. Low-tech, yes but it works.
carguy16
04-23-05, 05:04 PM
Afraid there is no code 49 in my book either.
Try the HVAC code puller, press and hold the off and warm button at the same time, if you have a manual it says it in there, section 8D6.
