: Flex disc / driveshaft coupler Camaro part number & SGF replacement
AggieV
10-06-13, 08:31 PM
The Short:
I have a 2005 CTS-V. Is this the correct Camaro part for replacing the drive shaft coupler:
92249108 (http://www.tonkinonlineparts.com/p/__/COUPLING-KIT-Propeller-Shaft-Pinion/6371924/92249108.html)
The Background:
I just purchased a 2005 CTS-V a few days ago with 81k miles. The diff swap was done by the original owner. Only other obvious upgrades are B&M shifter, Lingenfelter CAI, and Magnaflow exhaust.
Looks like all the soft stuff in the driveline is worn out (rather expected), and I've ordered the Creative Steel kit already. Since the shop will be dropping the diff to do the bushings, I ordered the GForce axles to be swapped in. With all the work being done, I figured I might as well replace the driveline coupler (flex disc, six-shooter) at the same time. I've had the car gone over by both the local Caddy shop and a very experienced GM Master Tech. Neither has called out this as an issue, but since everything will be apart already...
So, I have pretty well exhaustively read everything there is to read about drive shaft couplers on this forum and the LS1TECH forum. It looks like for a Gen 1, I have the following options:
Complete OEM Drive Shaft (not really an option)
Aftermarket Drive Shaft (probably out of budget)
RevShift Flex Disc (and possible driveline alignment work)
2010 Camaro part
The last two options are the ones that I prefer. I'll be calling the shop on Monday to see if they would be comfortable doing the tranny alignment and installing the RevShift part. Or... I'll be fine getting the Camaro part. I don't really plan on doing a bunch of HP upgrades on the car anytime soon. I want this to last a long time and don't want to introduce additional wear into the system.
So, with all that said, is the Camaro part listed above the correct one? Should I expect a GM Master Tech to be able to align the drive line well enough, or should I be looking for a specialty shop? (I'm in Austin).
Has anyone actually used the Camaro part with success?
PISNUOFF
10-06-13, 10:21 PM
I don't recall hearing about anyone trying it. Are you sure it cannot be purchased separately from the dealer? Give Luke at Lindsay Cadillac a call and see.
AggieV
10-07-13, 11:14 AM
Just got off the phone with Luke, and he hasn't heard of anyone using the Camaro part.
I'm wondering if the RevShift product would do okay since I'm remounting everything in the drive line anyway -- motor mounts, tranny, diff... Of course, that's all with CS parts but they should be the same spec's, right?
I'm not planning on doing any HP upgrades in the near future, so perhaps I'll just order the Camaro part and give it a go.
Anyone have an opinion? I'm very new to this car.
AAIIIC
10-07-13, 01:20 PM
The Camaro part has been mentioned in the past, like in this thread (http://www.cadillacforums.com/forums/2004-2007-cadillac-cts-v-performance/226621-bad-ass-couplers-soon-reality.html) and this thread (http://www.cadillacforums.com/forums/2004-2007-cadillac-cts-v-performance/254627-driveshaft-coupler.html). Revshift said the parts are different, but a couple of folks said they were the same. I don't know what the right answer is.
AggieV
10-07-13, 01:34 PM
Looks like I'll play the guinea pig on this one. I found a local dealer that will let me special order the part running the risk of a 15% restock fee. That's about what I'd have to pay to ship it back to someone if it doesn't work, so that's a wash. Since everything will be torn apart next week, I'm going to include this part. I'll go take a look at them both with the tech once it's all disassembled and decide from there.
I'll let everyone know what I find out.
Honestly, if anyone else has dealt with this and found a solution you like, please let me know.
AggieV
10-17-13, 09:10 AM
UPDATE:
When I looked at the parts side-by-side, the new part (number above) did look like it had slightly different metal collars. However, the dimensions of the part seemed to match. I've had it on the car now for about 125 miles, including a fair amount of highway driving. No vibrations at any speed. For those of you looking to replace the stock part with a similar stock part, it looks like this is a good option. I wish there was a Creative Steel option that was in-between this part and (what appears to be) the very unforgiving RevShift part. Since I'm mostly stock, I didn't think I needed an upgraded part here. The stock one looked worn, but no tears after 81k miles on the original.
06VaporTrail
02-03-15, 10:25 AM
So you did go with the Camaro flex disc? Did the drive shaft need [to be] aligned? I was going to attempt this job on my own. Looking at the Rev Shift instructions the exhaust needs [to be] dropped to gain access to the drive shaft. Then make sure to have a mark to assemble the drive shaft back in the original position.
Thanks for the info. Mine needs [to be] changed due to vibration issues.
AggieV
02-03-15, 01:39 PM
Yes, I used the Camaro part. I didn't take anything to get realigned, and I haven't had any issues. I did this right after I purchased the car. It had 81k miles, so it was time for all the soft stuff in the drive train to be replaced. So, I took the "while you're in there approach" to save on labor. All at once I did:
* Creative Steel motor mounts
* Creative Steel trans mount
* Creative Steel diff bushing and diff block
* GForce axles
* Camaro drive shaft coupler (guibo)
I've been quite happy with the results. However, everything was loose enough in the car when I bought it that I didn't really drive it until all the work was done. With just over 100k on the car now, I'm quite happy with how tight everything still is. The sales guy at the shop loves it when I bring my car in for him to work on. He used to have one himself. This is his after new cams and cat-delete: https://www.youtube.com/watch?v=cEbmaGVYZsw
06VaporTrail
02-09-15, 09:35 PM
Thanks for the info. I am going to order on tomorrow. Glad it worked out for you.
vettepoweraddict
03-18-15, 03:12 PM
I just Installed this flex coupling 92249108 (http://api.viglink.com/api/click?format=go&jsonp=vglnk_14267054358168&key=99b92d6e152eb9d1dde89f41fbc2db4b&libId=i7f3kp940100272e000DA17zci0n9ma5f8&loc=http%3A%2F%2Fwww.cadillacforums.com%2Fforums%2 F2004-2007-cadillac-cts-v-performance%2F380585-flex-disc-drive-shaft-coupler-camaro.html&v=1&out=http%3A%2F%2Fwww.tonkinonlineparts.com%2Fp%2F_ _%2FCOUPLING-KIT-Propeller-Shaft-Pinion%2F6371924%2F92249108.html&title=Flex%20Disc%20%2F%20Drive%20shaft%20Coupler% 20Camaro%20part%20number&txt=92249108) in my 2005 CTS-V and it fits perfect and is too made in Germany. My vibration is now totally gone feels like a new car. My old one did not look bad but compared to the new one it was a lot "harder". I'm guessing that because the exhaust system runs right below it over time it baked it"
The only bad /scary part is removing the exhaust system to gain access to flex coupling bolts make sure to spray some brand of rust/penetrator before you begin on exhaust bolts
ctsv247
03-18-15, 06:47 PM
First I've heard about the flex disc getting hard over time but it makes total sense. Thanks for posting....
AAIIIC
03-18-15, 09:46 PM
Good to get confirmation of one that fits, with the part number and everything. Thanks!
ctsv247
07-19-15, 12:02 PM
based on info here, I purchased a camaro flex disc as a replacement for my old V1 unit. Got the impression this was a direct swap but of course, it isn't.
http://www.cadillacforums.com/forums/2004-2007-cadillac-cts-v-performance/380585-flex-disc-drive-shaft-coupler-camaro.html
The V1 disc has collars on either side that allow it to index into the transmission and the driveshaft. The camaro unit has these collars too but unforutnately, one side is different that the V1 disc so it won't index as needed.
The collars on the V1 disc are the same size on either side whereas the camaro disc are different sizes on either side.
Not excited about putting this in without it being properly indexed.
Any thoughts?
ctsv247
07-19-15, 07:12 PM
I went ahead and installed the Camaro part because after considering my options, I figured out that I really don't have any....its the Camaro part or nothing so in it went.
I tried pressing the collars out of my old flex disc in an attempt to swap them over but that was not happening.
When I first posted, I was in that "just crawled out from under the car" delirium but after I chilled out for a few, I realized that the driveshaft is indexed off the output shaft directly which leads me to believe that the flex disc is sorta kinda just along for the ride.
I installed it with the side that would index going into the driveshaft for no particular reason. I was also concerned that the extra thickness created by thicker collars not seating into the output flange might bind things up a bit but the shaft still floated nicely even with the extra length created by the non indexing nature of the new flex disc. With the bolts installed, there was very little movement side to side through the bolt hole so in the end, I don't think the driveline is missing this lack of indexing on one side of the flex disc.
While I was at it, I used the "revshift" method for checking alignment and found that I had to elongate the holes in the carrier bearing mount in order to move it over enough to get where I need to be.
Was it worth...hell yea. The car has never been smoother despite my reservations about using this part.
odla
07-19-15, 10:22 PM
Good to know. Thanks! Do you have the part number of the replacement?
ctsv247
07-20-15, 09:40 AM
I used the 92249108. Ordered it from Luke at Lindsay and he was within $5 of everyone else and I actually dealt with a human. Saw the part in 3 days.
ctsv247
07-20-15, 07:53 PM
The CS bore scope alignment tool is brilliance. Simply slide it over the indexing shaft on the transmission....
lollygagger8
07-23-15, 11:44 AM
Good info!
luc082
08-04-15, 05:51 PM
I just received mine today and ordered it off GM parts direct part#92249108. Mine only came with 3 bolts, nuts and two of the washers fell out of the box. Did the rest of yalls come with 6 or 3 bolts? Do you have suggestions on replacement ones at a local auto store? would rather use Hex head vs the star bolts sent.
luc082
08-05-15, 10:14 PM
Where do you get this from the bore alignment tool? I just got my coupler part#92249108. I was scared to install it too because of the difference with the indexing bushing? I had a revshift coupler on there also have the voodoo center carriage bushing but had horrible vibrations.
ctsv247
08-06-15, 04:04 PM
Creative Steel will rent you this tool.
The camaro disc would have to be better than the revshift part. IMHO and as far as I know, I haven't seen any confirmable reports from any reliable sources that the revshift part will work unless your driveshaft is perfectly straight and perfectly aligned with the output flange of the transmission. The reason it doesn't seem to work that well is because none of use have perfectly aligned driveshafts and at least mine wasn't perfectly straight either although it was very very close. The output flange "fingers" didn't seem to be perfectly straight with each other either based on checking the runout of the output flange with a dial indicator...close, but not quite. Because none of this is perfect, the disc has to flex at least a little to make up for these imperfections and the revshift part, as far as I'm concerned, is to hard to flex as we need it too. As the factory V1 disc ages, it gets pretty cooked and thus starts loosing its ability to flex and the more out of line your driveshaft is, the more the disc will need to flex.
This will all be magnified by motor and transmission mounts that may change driveshaft angles as they sag with age or from replacements that are slightly taller or shorter than the factory mounts are designed to be. The UMIs I previously had in the car were not great in this regard and I was glad to get rid of them.
The camaro part seems to be working well in my car but if I ever see a need to take the car that far apart again, I will be trying to modify a camaro disc to work 100% in the V1. I'll do this by taking it to a machinist I use for work and blackmailing him into at least trying to either machine down the collar or drill it/cut it out and press in a new insert/collar. We'll see but for now, the camaro disc it is....
ctsv247
08-06-15, 04:13 PM
Mine only came with 3 so I just reused the old ones....
AAIIIC
09-23-15, 09:40 PM
I'm going to be installing a voodoochikin improved driveshaft in the near future, so I was looking around online to see about replacing the flex disk while I've got things apart. Since the Camaro part isn't quite a direct fit, I did some more looking around. Rockauto.com lists a Dorman part number that isn't correct - they (Dorman) show the same parts for the V6 and CTS-V, but the driveshafts are different, as are the flex disks. On ls1tech, Revshift posted a couple years ago that they had bought the Dorman part and compared it to a stocker and it's not right.
In searching around I stumbled across this ad on Ebay for an SGF (German company) flex disk for $95 (http://www.ebay.com/itm/201328982731?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT). The listing shows they've sold some, but I don't believe I've seen anyone post about these here or on ls1tech. I looked at their website (which is towards the bottom of the Ebay listing) and they list the flex disk separately there for ~$25 more than the Ebay listing. Of note, their web site shows 3 CTS driveshaft options (looking at a 2005 CTS) - V6 manual, V6 automatic, and CTS-V manual - as they should. Unlike the Dorman part, these guys show a different flex disk part number for the CTS-V, which strikes me as a good sign, since we know the parts are actually different.
I took the part number from their ad and went looking for that elsewhere online. WIPGAP01-003 doesn't come up with anything, but GAP01-003 does - www.powertrainindustries.com shows that as the flex disk that comes with their 3694-221 driveshaft assembly for our cars. OK, good, now I have 2 separate sites listing that as the correct flex disk. Interestingly enough, that part number also comes up as the flex disk for the '03-10 Porsche Cayenne / VW Touaeoeueareg ;); Rockauto.com shows Dorman 935-107 for that application for ~$95.
Even better, if I search for SGF GAP01-003 on Amazon, I find it for only $79 (http://www.amazon.com/SGF-GAP01-003-German-Coupler-Circle/dp/B00MYF4IP2/ref=sr_1_1?s=automotive&ie=UTF8&qid=1443051448&sr=1-1&keywords=sgf+GAP01-003). That's $15-20 cheaper than the OEM Camaro part that started this thread, which seems like a pretty good deal to me.
AAIIIC
09-25-15, 08:12 AM
I went ahead and ordered the SGF part (GAP01-003) from that Amazon listing. I don't think I'll be doing the driveshaft replacement until the 2nd weekend in October, so it'll be a little while before I have confirmation that the part is correct, but I don't expect to have any issues.
AAIIIC
09-28-15, 09:21 PM
I received the SGF part today (ordered on Friday from Amazon, received on Monday, free shipping - booyah!). Dimensions and markings seem to match up perfectly with details for the OEM flex disk posted by another member over on ls1tech. I won't actually get around to installing it for another couple weeks, but it seems that SGF GAP01-003 is legit.
AAIIIC
01-16-16, 01:19 PM
Back in October I installed my new SGF flex disk, but I never updated this thread. I learned something new today about how the flex disk is supposed to be installed, which reminded me of this thread. I'm going to have to get under my car to check out the flex disk, because I didn't even know to look for this when I did the install a while back.
The install was relatively straightforward. My old one didn't appear to be in terrible shape - I've seen some that were heavily cracked and degraded, whereas mine looked OK. However, the rubber had definitely been worked over the years such that once it was unbolted it was no longer flat / straight:
http://www.submariner.org/thepno95/Pictures/CTS-V%20pics/Drivetrain/Driveshaft/flex%20coupler1%20-%20old.jpg
My new coupler doesn't have the Porsche / VW part numbers on it. However, comparing the old vs new side-by-side, you can see the markings all match up, and the Porsche / VW part numbers have clearly been ground off the new one - you can see the little scuffed rectangles where the part numbers used to be. I've seen that on other plastic and rubber aftermarket parts I've bought over the years. I'm guessing it's a contractual thing, that the automakers don't allow the parts manufacturers to sell OEM parts, so the part manufacturers just delete the OEM part numbers for legal reasons.
http://www.submariner.org/thepno95/Pictures/CTS-V%20pics/Drivetrain/Driveshaft/flex%20coupler2%20-%20old%20and%20new.jpg
As for the new piece of information I learned today... On the side of the flex disk there are molded-in arrows at each bolt hole. Those arrows must be pointing towards the flange at each bolt hole in order to ensure the flex disk is oriented properly. I just assumed the thing was symmetrical, but according to this diagram from SGF, the structure inside the rubber is actually not symmetrical - it alternates thick and thin between the pairs of bolt holes:
http://www.submariner.org/thepno95/Pictures/CTS-V%20pics/Drivetrain/SGF%20install.png
If you install the disk rotate one hole off, the thick and thin structures won't be oriented correctly. This picture borrowed from Bavarian Autosport shows what the arrows look like:
http://www.submariner.org/thepno95/Pictures/CTS-V%20pics/Drivetrain/Flex_Disc-0192.jpg
You can see those same arrows on the "bent" old flex disk in my picture above. I vaguely recall seeing those on the side of the flex disk, but I didn't realize that they meant anything, so I have no idea if I aligned them properly.
Edit: Not quite as interesting a discovery as I thought. The extended sleeves that the bolts pass through mate up with the tranny and driveshaft flanges, so that ensures that the arrows are pointing the right direction. You'd have to bolt it up with the sleeves not engaging the flanges to get it wrong, and that would be pretty obviously wrong.
Scott2012
03-06-16, 05:34 PM
So I'm getting some minor vibrations more at higher speed. I thought about just ordering stock replacement parts and taking my driveshaft in to be balanced. I have slight mods and don't track it. Would anyone suggest this or go down different path?
AggieV
03-06-16, 06:00 PM
First off, there is technically no stock replacement number for the flexdisc. There are a couple of options discussed here: the GM Camaro part and an SGF part.
When I changed my flexdisc (to the Camaro part), I had 81k miles on the car. I did a bunch of work all at the same time because (a) it needed to be done and (b) the drive shaft was coming out anyway. So, all at once I did:
* Engine mounts (Creative Steel)
* Transmission mount (Creative Steel)
* Flexdisc (GM Camaro part)
* Diff bushing (Creative Steel)
* Diff block (Creative Steel)
* Gforce Axles to get rid of the wheel hop
It all works together fine. You might want to check the other soft bits in the drivetrain -- especially the trans mount since that can help to wear out the flexdisc.
darkman
03-06-16, 06:05 PM
Whether I would take a different path depends on what you have already checked and/or eliminated. Statistically, most high speed vibration issues are tire, or wheel related - tire wear, balancing, bent wheel, etc. Additionally, the V can develop high speed vibrations particular to 6th gear (or on rare occasion 5th gear) due to a known transmission issue. Finally, there are potential vibration issues with the axle CV joints. Assuming all that has been eliminated, the path you discuss is probably what I would do. I am however, bias toward the stock driveshaft and related components.
Derek5.7
03-11-16, 10:01 AM
Just came across this thread: I'm going to have my tranny out soon and thought it might be a good idea to replace the flex disk since the car is 10 years old, has 160k and I suspect, like others, that the rubber is pretty hard at this point due to age and heat. What is the consensus guys - I have the part numbers for the Camaro option and the SGF - which one seems like the better option? And dumb question: I assume GM doesn't have a direct flex disk replacement for our cars, hence this whole thread/exploration of legitimate OEM replacements?
I checked out the SGF one on Amazon - that one seems like about as close a direct OEM replacement as we're gonna get if GM/Cadillac really doesn't offer a direct replacement anymore. SGF says they make these flex disk couplers for Cadillac too. Any reason I shouldn't pull the trigger on this?
AAIIIC
03-11-16, 02:11 PM
The Camaro part can work, but the SGF part is the OEM part. I don't see any reason not to get the SGF unit.
Derek5.7
03-11-16, 02:37 PM
It's done - I ordered the SGF unit from Amazon (good price too). Thanks for the research/write-up on this option. Really appreciate it.
Scott2012
03-11-16, 10:29 PM
Well, I have rev shift motor mounts, rev shift rear diff bushing, rev shift trans insert. I have no idea how to check the transmission- it shifts fine (I have the ls7 clutch now). I'm good with aftermarket components, but stock is also OK.
darkman
03-12-16, 08:15 AM
Attached is general information regarding diagnosing vibration.
Balancing your driveshaft is unlikely to do any harm, but it may, or may not address your vibration issue.
Looking at the list of your existing modifications, there are two that can introduce vibration. One is the LS7 clutch, which can introduce vibration unless the pressure plate and clutch disc were balanced as a package before installation. This source of vibration, an unbalanced LS7 clutch, reportedly diminishes over time.
Another potential source of vibration is the Revshift transmission insert. This is not because there is anything wrong with the Revshift insert, but rather because the driveline alignment in the CTS-V has a narrow range "tolerance." Based on numerous reports on this forum, replacement transmission mounts are a crap shoot - some transmission mount replacements/inserts work with certain motor mounts in terms of vibration, but not with others. This sometimes necessitates some trial and error with transmission mounts/inserts. (The stock transmission mount is expensive.)
If either of the two modifications are the cause of your vibration, you would likely know it because the vibration would have showed up coincident with the change.
KB V
04-29-16, 12:05 PM
I did the voodoo service, new factory flex (amazon), cs trans mount. I am now getting drive shaft vibes around the 55mph mark (coasting or on the gas). I also have revshift mm and cs trans bushing and block. Voodoo says to "try shimming carrier down with washers just a bit to resolve any alignment issues". Anyone have this experience? And did you get it resolved?
Rough_Idle
04-30-16, 01:56 AM
Yes, you can put the 3 bolts for testing alignment coming from trans through the coupler direct into the 3 holes from the driveshaft flange and then look after fasten them together, where the gap is, put 1 washer on mine every side and it's complete on driver's side, so much, the bolt holes of bearing bracket allow me to go!
Did you have balanced your driveshaft after changing the middle bearing?
Regards
Ronald
KB V
04-30-16, 09:02 AM
I thought that balancing was part of the bearing service, so I don't know if it was or not.
ctsv247
04-30-16, 10:04 AM
No it isn't.
darkman
04-30-16, 11:07 AM
https://www.youtube.com/watch?v=kj78G4wtXKE
GMBOUND
05-23-16, 06:37 AM
Sounds Great!
caddy_cts
12-06-16, 04:13 PM
Hey guys......found the part @ https://driveshaftpro.com/# talk to bryan @ driveshaftpro 714/462-1199, its an exact fit
AAIIIC
12-06-16, 05:41 PM
We've already found the part on Ebay and Amazon.
